Old 12-05-2008, 12:08 PM   #2791
imprsme's Avatar
Trader Rating: 74 (99%+)
Originally Posted by ChristopherKee View Post
If you accidentally mixed all your rdx black springs in your kit up, how do you tell them apart? I purchased the spring kit used and am clueless =/
Count the coils:
12.5lbs=6.25 turns
14.5lbs= 6 turns
17lbs=5.75 turns
19lbs=5.5 turns
22lbs=5.25 turns
24 lbs=5 turns
The way I do it is:
Hold the spring so that the starting coil on the top is on the side closest to you.
Don't actually count it, but count the coil just below it as one.
Then count each coil there after, the "left over" on the last coil will be the .XX.
Hope this helps.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 12-05-2008, 01:11 PM   #2792
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Thanks guys, that does help a lot. I do have the box with the numbers written on the front. The springs just weren't in there. Also, when I counted the coils, which is what I guessed, they all seemed the same =). Maybe I need glasses.
Thanks again.
ChristopherKee is offline   Reply With Quote
Old 12-05-2008, 01:24 PM   #2793
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 12-06-2008, 09:55 PM   #2794
has any one ran the LIPO adapter tray for the RDX Phi?
hows it compare to a 3800ib pack set up?
cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 12-07-2008, 08:41 AM   #2795
Trader Rating: 36 (100%+)
cheers guys
I'm curious about this information too. I currently run 3800 orion and IPs because they fit and I run pretty well with the rest of the field. If I use the tray and a larger battery like the 4800 or 5000 will I see much improvement or just run time?
EVILGRAFX is offline   Reply With Quote
Old 12-07-2008, 12:38 PM   #2796
Big Features's Avatar
I'm using the LIPO tray right now. I've also grinded the bulkheads and top-deck screw retainer and crammed the 3800 in the regular battery slot.
Trust me, stick with the tray. Its much easier to add weight and balance the car. If there is "wiggle" room when you put the battery strap on, use a piece of tire insert and you'll be sound as a pound.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 12-07-2008, 02:19 PM   #2797
Still Bill's Avatar
With a larger capacity lipo, you will defintely notice the extra voltage in the later half of a run. After a rim, I would have 2/10ths of a volt more with the SMC 5000 than my Orion 3600/3800 packs. That extra voltage translates to faster laps.
Totally agree that the car is better balanced side-to-side with the lipo/lipo tray offsetting the weight of the BL motor too.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-09-2008, 07:19 AM   #2798
Kenny L's Avatar
Trader Rating: 16 (100%+)
Has anyone tried the new rear vertical ballstud uprights? Was wondering what to expect. I should have mine soon. Will post up my thoughts.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-12-2008, 02:43 PM   #2799
Will the AE or XRay wheel hexes work on the RDX?
slow is offline   Reply With Quote
Old 12-12-2008, 03:10 PM   #2800
Not sure, never tried them. Corally makes narrow and wide hexes for the PHI and you should be good to go with those. I've used Tamiya ones in the past on my RDX though..............
Mike
Mike Kling
Old 12-12-2008, 03:16 PM   #2801
ricker96's Avatar
i like the way the car feels with the lipo tray, balance is good and transition left to right feels very stable and no lifting, i've used it now for about 4 months and it's much easier to use the tray then strapping a smaller 4000 or 3600 lipo to the chassis
ricker96 is offline   Reply With Quote
Old 12-12-2008, 04:22 PM   #2802
Mike
I have the Corally hexes but all my narrow ones are broken now. Just wanting to know if there's an alternative.
Old 12-12-2008, 06:36 PM   #2803
ok are the pro's using tamiya shocks or the kit phi shocks?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 12-12-2008, 07:01 PM   #2804
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Tamiya 4mm, 5mm etc fit. Just need to add a couple of shims on the axle for slop.
SchuMi2 is offline   Reply With Quote
Old 12-12-2008, 10:20 PM   #2805
can some one please give me the part numbers for the low ratio drive train ..
I got the 36t pulleys I need a smaller rear belt, and from what i read different bearing holders.I am not using the short wheel base... Big thanks Vinny
tc4me is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
