Old 11-12-2008, 10:01 PM   #2761
Jeff Brown's Avatar
Originally Posted by wide_mouth_frog View Post
Just a quick question...
What would I get if i moved my rear camber link all the way in on the shock mount... and on the top hole on the rear hub...
and if i go outer hole on the shock mount and outer on the hub (opposite to the above)
I know it will effect the roll, but just wondering how that will translate on the track
Cheers
Ok...... you are changing a lot with that.
Long, short, this and that.
Bottom line is........ angled links give more side bite due to camber change. Flat links give more forward bite. It is a balance of what you want.
Rember that the standard rear hub links are not the same as the option hubs. When you shorten the link it will free it up, but going too short can effect forward bite. So if you go up on the rear hub, but do not adjust the shock tower location it will be a big difference.
Jeff
Jeff Brown is offline   Reply With Quote
Old 11-12-2008, 10:46 PM   #2762
Still Bill's Avatar
Originally Posted by Big Features View Post
Still looking to pick up a used PHI for T/A........
Anyone.........Anyone...........
PMed you. My indoor and outdoor setups are so similar, I only need one car these days. See my questions in the PM.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-16-2008, 07:18 PM   #2763
Big Features's Avatar
Bill
Bill,
Did you get my PM??
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 11-16-2008, 08:01 PM   #2764
Still Bill's Avatar
Bill,
Did you get my PM??
Mike
Mike,
Yep...Was racing and watching the Worlds most of this weekend.
PMed you back about 30 minutes ago...LOL
Bill
Old 11-18-2008, 05:06 AM   #2765
s.nicholson's Avatar
Send a message via MSN to s.nicholson Send a message via Skype™ to s.nicholson
Hey guys thanks to all the corally team over in thailand for support, now back in Aus and prepping for our national titles this weekend.
Team Yokomo/Panaracer/LRP/Xenon
Roche/Pro-Spec
Sanwa
s.nicholson is offline   Reply With Quote
Old 11-18-2008, 09:01 AM   #2766
OllieRDX's Avatar
Send a message via MSN to OllieRDX
Hi,
Congrats with the result on the worlds!
Did you do something special with the car?
Greetings Ollie
OllieRDX is offline   Reply With Quote
Old 11-18-2008, 07:04 PM   #2767
Originally Posted by OllieRDX View Post
Hi,
Greetings Ollie
nope just standard
Roche/Pro-Spec
Sanwa
Old 11-18-2008, 09:03 PM   #2768
Still Bill's Avatar
nope just standard
That begs the question...What is "standard"?
Old 11-18-2008, 09:28 PM   #2769
touringdriver's Avatar
Trader Rating: 15 (100%+)
Ditto on that question.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 11-19-2008, 02:29 AM   #2770
The car is how you would build it out of the box except for tamiya shocks and front alloy knuckles.
Roche/Pro-Spec
Sanwa
Old 11-19-2008, 07:01 AM   #2771
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
I think maybe everyone was looking for a little more insight as to your setup used for the worlds. Maybe as compared to the one you have posted on the AU Corally site.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 11-19-2008, 05:34 PM   #2772
gone_wheelin's Avatar
Default Pinions
Is it just me, or is it nearly impossible to get an allen wrench into the pinion set-screw with the motor installed?
I've got the stock motor plate and a BL motor installed. I also can't get the pinion set back far enough on the pinion shaft to line up properly with the spur gear. The driver hits the motor plate and holds the pinion about an 1/8" out past the spur.
Is this the reason I have seen posts where the pinion is being flipped?
Redwood Empire Ground Pounders ~ Team CFX ~ Jakes Performance Hobbies
gone_wheelin is offline   Reply With Quote
Old 11-19-2008, 05:41 PM   #2773
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
You can run the pinion flipped like that, but then the setscrew usually ends up hitting the front belt and slowly chewing it up.
I usually put the pinion on before installing the motor. If you slide it down so the setscrew is as far down the flat as it will go, the alignment is pretty much dead on. It's not the most ideal thing for quick pinion changes, but if you're loosening the motor screws to change the gear mesh anyway, it's not that much slower to take them out to make setting the pinion easier.
JamesArluck is offline   Reply With Quote
Old 11-23-2008, 11:54 PM   #2774
B4james's Avatar
A big Congratulations to Simon Nicholson for continuing his good worlds form and capturing the Australian National modified title over the weekend,
That makes it back to back Australian Nationall title wins for him and the Corally PHI, well done mate
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 11-25-2008, 03:04 AM   #2775
Thankyou very much, When i get some spare time i will be taking some photos of my car to put up on here to show everyone how standard it is.
Roche/Pro-Spec
Sanwa
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
