Old 11-06-2008, 08:43 AM   #2731
wide_mouth_frog's Avatar
Just a quick question...
What would I get if i moved my rear camber link all the way in on the shock mount... and on the top hole on the rear hub...
and if i go outer hole on the shock mount and outer on the hub (opposite to the above)
I know it will effect the roll, but just wondering how that will translate on the track
Cheers
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 11-06-2008, 09:10 AM   #2732
OllieRDX's Avatar
Send a message via MSN to OllieRDX
Cheers
Hi,
If you go for a long camber link on the shocktower you will create less grip
If you go for a short camberlink your car wil be more agressive.
Then for the rear upright the outer hole will make the car more stabil the inner hole wil make the car verry agressive!
Grts Ollie
OllieRDX is offline   Reply With Quote
Old 11-06-2008, 09:16 AM   #2733
OllieRDX's Avatar
You need the tamiya connectors above and on teh bottum i use the corally connector and balls with the corally shockcollar!
Grts Ollie
Originally Posted by IL_AudiRacer View Post
My new TRF shocks have just arrived. but noticed the Ball end holes are much smaller than the Corally ones. How are you guys installing these ?.
Just switch to Tamiya Ball nuts all the way arround ? Corally or Tamiya Connectors on the shock shafts
would i use tamiya
53599
and these ??
53598
Thanks for the help this is gonna solve so many of my headaches with this car
Old 11-06-2008, 09:26 AM   #2734
Thanks Olie, but what I was meaning is to keep the same length... just move it inboard and out board... if that makes sense?
Old 11-06-2008, 09:36 AM   #2735
Johnny Wishbone's Avatar
If you where to leave the link the same length, but moved to the different locations you will see a change of approximately 1/2 degree camber change, so from the lowest to the highest you could see 1 total degree of difference. That would be at static setting as the car rolls in the corner that change will dictate more or less lean of the tire going thru the corner or camber gain.
Old 11-06-2008, 11:55 AM   #2736
Big Features's Avatar
A longer camber link should make the care feel a bit lazy and generate more grip as there is more roll. The angle affects roll center and canber gain all at once. A more parellell link will take gip away and there is less camber gain. Thats what I've always seen.....
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 11-06-2008, 12:43 PM   #2737
Holmenkollen's Avatar
Grts Ollie
Does the Corally shock collar work well with Tamiya springs?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 11-06-2008, 02:30 PM   #2738
OllieRDX's Avatar
No, but we never run the tamiya springs anymore allmost everywhere the HB springs!
Greetings
Old 11-06-2008, 04:01 PM   #2739
touringdriver's Avatar
Trader Rating: 15 (100%+)
hi guys. i justc got a rdx phi to race asphalt next spring. . looking for a good setup to start the tweak season off. any suggestions would be greatful.
i have 2 rdx cars and thought they were sweet! but this phi is badddddddd.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 11-07-2008, 04:34 AM   #2740
Greetings
Wich springs?
Old 11-07-2008, 04:37 AM   #2741
I believe he is talking about the HotBodies / hara springs.... many people are using them now...
Old 11-07-2008, 05:28 AM   #2742
I meant wich spring rates. Ive tried gold/silver.
Old 11-07-2008, 05:31 AM   #2743
ahhhhh sorry
Old 11-08-2008, 10:41 PM   #2744
Love the car and would love to keep it, but just can't afford to have 3 touring cars and have one lying around. Loaded car for sale:
http://www.rctech.net/forum/r-c-item...y-rdx-phi.html
JoelV is offline   Reply With Quote
Old 11-09-2008, 04:14 PM   #2745
Vicko's Avatar
Trader Rating: 14 (100%+)
Hey anyone know the part # for the BL motormount for the PHI?
Vicko is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
