Old 10-31-2008, 08:20 PM   #2716
imprsme's Avatar
Trader Rating: 74 (99%+)
Originally Posted by Big Features View Post
Thats what I'm talk'n about fool!!!
How much wieght do I need to add to the car to make it balanced/legal??
With the IP I added 19 7 gram weights to the outside of the batteries.
I did that so I could use either of the batteries in either car. My rubber tire car already had weights to get to 1525 w/ cells anyway so I just let them as they were, and the 133 grams I added with the lipo got my foam car to 1421.
It will depend on what electronics you are using also.
But 130 grams will get ya close
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 11-01-2008, 05:17 PM   #2717
THeGame's Avatar
Send a message via AIM to THeGame
Why are you guys running Tamiya shocks and not the stock shocks ?
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 11-01-2008, 06:39 PM   #2718
revsinc's Avatar
Trader Rating: 15 (100%+)
Talking
Monkey see, Monkey do !
Full Speed , Half Price
revsinc is offline   Reply With Quote
Old 11-01-2008, 06:50 PM   #2719
Big Features's Avatar
I'm only running the Tamiya ones because I had them laying around and they are idiot proof. They are extremely easy to use.
Every car I've ever had, the 1st thing I do is put Lundsford turnbuckles and Tamiya shocks on it. Just because, no other reason.
I havents even built the Corally shocks yet
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 11-04-2008, 04:38 AM   #2720
mazmo's Avatar
Default Handing problems
Guys, have a handling problem with my Phi & would appreciate your advice.
Main issues are:
1) Major oversteer - middle of fast corners (on & off throttle).
2) Poor stability with quick direction changes - again oversteering.
Have tried various combinations, but just can't seem to get rid of the oversteer
Have attached pdf of my latest set up, would appreciate any guidance
Cheers
Alan
File Type: pdf RDX Phi Setup Sheet Mazzaroli Windsor 24.10.08.pdf (372.4 KB, 253 views)
mazmo is offline   Reply With Quote
Old 11-04-2008, 07:45 AM   #2721
Still Bill's Avatar
Main issues are:
Cheers
Alan
Hey Alan,
I don't see anything really unusual in your Phi setup. My droops would be 5/5mm. Are you not allowed to use Tire Additive at Windsor? Have you checked for bad bearings?
I converted over to the super short wheelbase for asphalt several months ago; but, that probably would worsen your hooking problem.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-04-2008, 09:13 AM   #2722
Any new developements coming for the Phi or even a new car as im tempted to pick one up but dont want to be left dehind as something new comes out within a month or so.
weekendracer_uk is offline   Reply With Quote
Old 11-04-2008, 09:26 AM   #2723
imprsme's Avatar
Looking at that set-up it seems pretty standard.
Maybe play with the D/R and end points. You may have too much wheel input. Maybe.
Here is what I do for End point and D/R.
Set both to 100%
Turn the wheel full lock in one direction, now back off on the end-point until the steering knuckle just moves from the c-hub, Repeat on the other side.
Then I adjust D/R as needed on the track.
Too much wheel input can make the cars act very strange.
AwesomatixUSA
eXpress Motorsports
Old 11-04-2008, 09:29 AM   #2724
wide_mouth_frog's Avatar
Main issues are:
Cheers
Alan
Also check your rear hinge pins are not bent in anyway... you need to roll them on a flat surface and get level with it, as the bend will only be small at the end.
I had the same problem sunday, car just kept hooking in... tried all day to sort it and got home to find that!
Doh!... better late than never
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 11-04-2008, 10:26 AM   #2725
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Check to make sure that your rear suspension mounts aren't bent in any way. All it takes is a slight tweek and it will throw your rear toe out of adjustment and make the car handle weird. I also check the rear toe with a setup station and make sure it's identical left to right. Sometimes you need an extra .5deg. shim on one side to even it all out.
JamesArluck is offline   Reply With Quote
Old 11-04-2008, 10:59 AM   #2726
Johnny Wishbone's Avatar
I'd change the front and rear droop.
Plus check all the above mentioned points.
Old 11-04-2008, 12:37 PM   #2727
mazmo's Avatar
Default Handing problems PHI
Thanks for all the advice & suggestions guys... l better get busy
Old 11-04-2008, 07:24 PM   #2728
Hey all,
I'm looking to pick up a 2nd hand Corally PHI to run in the T/A class at snowbirds. Anyone looking to unload one?
Mike Kling
Old 11-05-2008, 09:06 AM   #2729
Default PHI
Big Features, you have PM.
Old 11-05-2008, 07:45 PM   #2730
I'm looking to get a stiffer chassis for high bite conditions. Corally offers 2 different ones. One is 2.9mm same as the stock one but made with better quality material and is multi-woven instead of bi-woven from what I understand. Part number is 79838. Then they offer a 3.4mm chassis which is part number 79839. I'm not sure if is multi-woven or if it uses the same material as the 2.9 chassis. So my question is, which one would be the best one to get?
kobiwan is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
