Old 09-23-2008, 02:46 PM   #2656
[QUOTE=THeGame;4865958]Has anyone tried the short wheel base on carpet with rubber tires ?[/QUOT
I have. The car runs well. Who here runs the small diff pulleys for rubber tire on carpet? B when are you coming back to Mimi's for rubber?
samstheman2 is offline   Reply With Quote
Old 09-23-2008, 07:09 PM   #2657
mickrcarver's Avatar
Trader Rating: 98 (99%+)
http://www.rctech.net/forum/r-c-item...fs-extras.html
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 09-23-2008, 10:08 PM   #2658
Still Bill's Avatar
I do run the 36T pulleys on my asphalt and carpet (both rubber) Phi cars.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-26-2008, 08:02 AM   #2659
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
Whats the deal with Corally Parts Support ?? I have owned my PHI for a couple months now and it seems whenever i need a part there not available
im having nothing but probs with leaking shocks ?? ($500 car should not have leaky shocks i have 2 both leaking) and can not find the optional bladders anywhere, Also looking for front arms they have been out of stock since i bought my cars. I like the cars but cant keep taking weeks off due to lack of parts. Is there a reason for them being so hard to find ??
If this goes on much longer i will switch to different Brand Car
IL_AudiRacer is offline   Reply With Quote
Old 09-26-2008, 08:05 AM   #2660
RBLove's Avatar
Trader Rating: 72 (100%+)
I am interested to see this ultra short wheel base set up. Do any of you have a photo?
RBLove is offline   Reply With Quote
Old 09-26-2008, 09:38 AM   #2661
chicky03's Avatar
Send a message via AIM to chicky03
Are you using 1 or 2 orings in the shocks? If you switched to 1, you'll need to use additional spacers the take up the room in the shocks for the oring that is missing now. The only reason they could leak is that reason.
Superior hobbies has arms in stock. I just got some today.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 09-26-2008, 09:56 AM   #2662
THeGame's Avatar
Send a message via AIM to THeGame
here you go..
http://www.superiorhobbies.com/istar...page=25&pos=50
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 09-26-2008, 03:23 PM   #2663
Paul
They leak out of the top and when i remove the cap the bladders are
INSIDE the shock bodies. I have read that its a common problem and this is why people use the Tamiya or The Speacialized bladders.
here you go..
[url]http://www.superiorhobbies.com/istar...page=25&pos=50[url]
I have checked there im looking for the Fronts in 5% always out of stock.
Thanks for replies ! Brad i will give you a call
Old 09-26-2008, 03:36 PM   #2664
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
here you go..
http://www.corallyusa.com/2005/shocks.htm
Are you doing the trick with the X-acto handle to push down the bladder from the center? If the bladder has a little bubble popping up from the center or it isn't perfectly seated around the edges it won't seal correctly and your shocks will leak.
Also make sure that when you tighten the cap you do so by the aluminum nut and not by twisting the plastic eyelet. If you spin the eyelet to tighten it up you can unseat or tear the bladder that way.
-James
JamesArluck is offline   Reply With Quote
Old 09-26-2008, 07:29 PM   #2665
RBLove's Avatar
Originally Posted by RBLove View Post
I am interested to see this ultra short wheel base set up. Do any of you have a photo or exact details?
Anybody?
Old 09-26-2008, 08:00 PM   #2666
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Anybody?
Hope these are OK...
Team Corally RDX Phi-img_1378a.jpg   Team Corally RDX Phi-img_1379a.jpg   Team Corally RDX Phi-img_1380a.jpg   Team Corally RDX Phi-img_1381a.jpg   Team Corally RDX Phi-img_1383a.jpg
SchuMi2 is offline   Reply With Quote
Old 09-26-2008, 09:00 PM   #2667
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
So how does that car work with all those parts on it? And do you feel much of a difference with the shocks mounted on the back of the tower?
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 09-28-2008, 11:47 PM   #2668
Big Features's Avatar
Anybody?
Rob,
Here are some pics of my car. I run 36T pulleys and a TAM415 rear belt. I can sent you my set-up if you like car is balls fast and really easy to drive.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 09-29-2008, 07:51 PM   #2669
Still Bill's Avatar
Originally Posted by Big Features View Post
Rob,
Mike
Hi Mike,
I am running the ultra short wheelbase too with the 36T pulleys. Has been my only outdoor setup for the last 3-4 months now. Will be running it in the KO Propo Grand Prix at Speedworld this weekend.
There is a TRF415 low friction rear belt (white) available too. It is Tamiya Part No. 53707.
I would be interested in seeing your Phi setup...What motor(s) is it for 13.5/10.5/mod?
Are you using a smaller spur gear than the Corally 98T 64P unit? If so, which one?
Thanks.
Bill
Old 09-29-2008, 08:04 PM   #2670
All,
Can someone send me a setup sheet in word or something I can use?! I'm not very savy on computers.
I've been working on this set-up for a while, trying new things and I've think I've nailed it for small/med track with med/high bite. Car is incredible
Mike
Mike Kling
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
