Old 08-22-2008, 11:10 PM   #2581
THeGame's Avatar
Send a message via AIM to THeGame
Originally Posted by Jeff Brown View Post
You do not want 79690, as that is the original PHI diff.
The 08 PHI Diff is 79680 and does not come with pulleys. The original 36T and 42T pulleys will still work.
We are out of stock on the new diffs for about 3 more weeks.
Jeff
Didn't I just see you this week.... you got Pm..
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 08-23-2008, 01:21 AM   #2582
Hey everyone
Just wanted to ask do you reckomend to run with sway bars or not? As the car i've just brought hasn't got them?
twitch_1 is offline   Reply With Quote
Old 08-23-2008, 11:22 AM   #2583
Big Features's Avatar
Originally Posted by twitch_1 View Post
Hey everyone
I would recommend picking up the 1.3mm front and rear sway bar kits. I personally run them most of the time, it just depends on the track.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 08-23-2008, 12:44 PM   #2584
THeGame's Avatar
Hey everyone
Are you running rubber tires or foam tires ?
Old 08-25-2008, 09:57 AM   #2585
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
Any tips or tricks for rebuilding Corally shocks ?? i have PHI and RDX and they have both had issues leaking out the top. Am I overtightening ?? Should i use a different brand bladder ?? A few times when i have removed the top the bladder is actually in the cylinder
IL_AudiRacer is offline   Reply With Quote
Old 08-25-2008, 10:19 AM   #2586
Drifter73's Avatar
I had the same problem, I even had someone else build them and they still leaked. I just switched to Losi 10mm shocks, but I still use the corally springs.
Spektrum, Team Orion, Orca
Drifter73 is offline   Reply With Quote
Old 08-25-2008, 10:40 AM   #2587
BJohnson's Avatar
IL_AudiRacer - The problem you are having is due to the bladders. I would suggest replacing the bladders with new ones from Corally. If that doesnt solve the problem you can switch to the Specialized RC bladders or the Associated bladders. If you swith to the AE bladders, make sure you use both pieces of foam in the bladder.
BJohnson is offline   Reply With Quote
Old 08-25-2008, 07:22 PM   #2588
Thanks Guys, I take it this is a common problem ? as most places are out of stock on replacement Bladders. what is the difference with the hard bladders are they more durable ? what effects will it make on the car it seems the mediums are sold out but the hards are available.
Old 08-27-2008, 02:58 PM   #2589
stuey's Avatar
use tamiya bladders it will never be a problem again
stuey is offline   Reply With Quote
Old 08-28-2008, 12:29 AM   #2590
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Had a decent first run with the Phi today but need to get some help so that I can put in an order for some parts:
1. What is the part number for the aluminum steering blocks? Do they come together or do you have to buy individually?
1. What is the part number for the coupler shims? How many come in a packet and in what size?
2. I want to replace the stock turnbuckles with lunsford titanium versions. What sizes do I need? Does lunsford have a set?
3. I have a little play in my spur gear pulley. It moves side to side about a 2mm. Is this ok or should I shim it out?
4. For carpet rubber (low/medium grip), do you recommend running the 1 mm or 2mm raised ball studs? If so, which one for what situation? What do these do for the car?
Any help would be appreciated. Thanks!
Chirag Patel (San Diego, CA)
1/10 2WD Buggy: TLR 22 4.0 SR 17.5
1/10 4WD Buggy: TBD
cpatel529 is offline   Reply With Quote
Old 08-28-2008, 08:28 AM   #2591
Do you happen to know the part #s or the size Diaphram/Bladder
also if you know where to get them would be great i guess while im at it i should order the Tamiya 3 hole Pistons too anyone know that part # ?
Old 08-28-2008, 12:42 PM   #2592
Just get the black tamiya TRF shocks (#84008) and call it a day
Mike Kling
Old 08-28-2008, 12:53 PM   #2593
1. Steering Blocks - #79278
2. Lundsford does not make direct replacements. You have to order them individually. The measurements for corally and lundsford dont match exactly, so just get close and use RPM ball cups.
3. Mine moves a tad as well. I shimmed my out alitte, but its not really nessessary.
4. I personally have not tried to run them, but the gereral idea is to angle the camberlink even more. This will "center" the car and it will feel like it has more initial grip.
Hope this helps. You can always call the gang at Corally USA, They have done exhaustive testing and can tell you for sure what does what.
Mike
Mike Kling
Old 08-29-2008, 02:27 AM   #2594
MSB
MSB's Avatar
Send a message via Yahoo to MSB
#79227 RDX shock Diaphragm (1 pair)
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 09-01-2008, 12:24 PM   #2595
Kenny L's Avatar
Trader Rating: 16 (100%+)
Big thanks to Cuffs,Robbie,and the rest of the Corally gang whos helped me out this last year you guys are the best.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
