Old 07-09-2008, 09:49 AM   #2386
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by RBLove View Post
Did I see Mr. D-n-S on some 1/8th scale onroad results??? He's an animal.
He's gotta race foams somewhere.
Also, I got gangbanged by the golden ratio this week.
syndr0me is offline   Reply With Quote
Old 07-09-2008, 11:48 AM   #2387
Originally Posted by smoke81 View Post
You need both of these
http://www.corallyusa.com/istar.asp?...=COR79184A!COR
http://www.corallyusa.com/istar.asp?...=COR79182A!COR
Only place i've seen them anyways... But that atleast will give you the partnumbers.
Hi,
Thank you, i am aware of the part numbers, yet they are not available in my country, this is why i need an alternate axle that would work.
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 07-09-2008, 03:09 PM   #2388
mazmo's Avatar
Originally Posted by The Bear View Post
Hey Mazmo,
For carpet, in my humble opinion, you have 2 basic choices.
1.) Front tire setup: using an indigo, cyan or some form of ‘front’ tire that has a harder foam on the outside is a time tested drive. Very ‘flowing’ with the default reaction being to ‘push’. Lots of lifting and rolling through corners to keep up speed.
a. I’d look at this setup: http://www.corallyusa.com/setups/PHI_boice1.pdf
2.) An all 1 foam setup: Using all magenta or all double pink foams (usually), this drive is much more aggressive and defaults to the back end kicking out or scrubbing in corners. However, you don’t lift nearly as much and its usually easier to stay in the line.
a. I’d look at this setup: http://www.corallyusa.com/setups/PHI_johnson1.pdf
i. I couldn’t find it, but the setup for Jeff Cuffs is amazing. Johnsons setup is wicked fast, but pretty twitchy.
You didn’t say what class you’ll be running, but I know these two setups will work for 13.5 and should be fine for 10.5. If you are running mod, I can’t speak for these setups from experience.
Good luck!
Thanks for your advice ... just wondering, with regards the tyres you have recommended, what shore rating would they be equivelant to (front & rear).
I am trying to decide on an equivelant tyre in Australia.
Oh .. by the way ... I am running 13.5 brushless
mazmo is offline   Reply With Quote
Old 07-09-2008, 03:37 PM   #2389
Mr Love.... I hear you have your own rubber tire "Sauce".....
and I love the quote you have from Smoke81, before he edited it- must
be his subconscious coming out
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, T.Q. Wire, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 07-09-2008, 04:09 PM   #2390
Trader Rating: 1 (67%+)
Bill Sydor................please call Scotty or Boomer immediately.
Your entry must be screwed up.......they have you signed up in 13.5 rubber.......we all know you don't run rubber..........or do you?
Josh Hohnstein is offline   Reply With Quote
Old 07-09-2008, 06:10 PM   #2391
RBLove's Avatar
Trader Rating: 72 (100%+)
RBLove is offline   Reply With Quote
Old 07-09-2008, 06:34 PM   #2392
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Tire sauce huh ?
So thats where the stuff you were collecting from seaball at the gate in the stall went to .
wallstreet is offline   Reply With Quote
Old 07-09-2008, 06:50 PM   #2393
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
I didn't edit anything... I got edited... For the better I must add
Dustin Layne
smoke81 is offline   Reply With Quote
Old 07-09-2008, 08:21 PM   #2394
Send a message via AIM to HenBeav
it was rice cake gangbang day, even the slosis got in on it (well almost all of them)
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 07-09-2008, 10:10 PM   #2395
vegas for me
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 07-10-2008, 01:41 PM   #2396
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Hi guys, I have been stepping into the on-road scene recently and bought my first TC....an RDX Phi.
After running it for a while, I noticed a few things and I'm working to improove.
The first item is the front bumper, well, the black "bat man" looking thing that sits under the foam. It gets broken very easily, bent, cracked and otherwise in a short period of time...often resulting in that part rubbing the race track and etc. I've been testing some different material and have found something that works extremely well, I've had a few drivers (dave ehrlich to name a few) testing these bumpers and have given them the thums up/nod of approval.
Basically, they hold their shape, dont break/crack etc...and at for the $15 shipped price, they'll pay for themselves after the first front impact.
Since I'm at work right now, I can't get a picture up, but I'll have one by tonight.
Soon to come will be rear "anti-body-tuck" plates that are effectively and efficiently worked into the chassis, I'll have photos of those soon. Also, I'm working on a front non-drag plate that fits under the "bat-man" plate...lower profile and raised a hair to eliminate drag while cornering.
PM me if you're in any way interested...
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 07-10-2008, 02:27 PM   #2397
Josh-
That would be correct, the entry is not screwed up, just me...
See ya in Vegas
Old 07-10-2008, 02:31 PM   #2398
RBLove's Avatar
Josh-
See ya in Vegas
What?????????????? You are going to run some rubber carpet this year? Awesome!
Old 07-10-2008, 03:59 PM   #2399
smoke81's Avatar
He has no choice to run rubber on carpet locally.. So we kind of forced his hand...
Dustin Layne
Old 07-10-2008, 06:00 PM   #2400
Josh-
See ya in Vegas
Thats what I thought!!!
So are you enjoying rubber tire racing???
Did you help give syndrome his beatdown last week?
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
