Old 05-14-2008, 10:58 AM   #2026
Mike:
I have not tried the super short wheelbase yet, however I have tried/am running the narrow steering blocks. I noticed that I gained a lot of initial steering when I switched to them. The car was more alive off center, and switched direction much faster through chicaines. However I did not notice a difference in the amount of steering gained through the middle of the corner and off.
P.S. How do you post a set-up? Does the setup sheet have to be hosted somewhere on the internet first?
Steve
Steve Bortolotti
S.Bortolotti is offline   Reply With Quote
Old 05-14-2008, 11:02 AM   #2027
Steve... Cool... I just type it out . But i do think it would have to be saved as pdf file and uploaded on here as a attachment...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 05-14-2008, 11:49 AM   #2028
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
Originally Posted by Mike Blackstock View Post
Brad... I use the kimbrough mid also... I use the short ball from corally facing towards the servo.. i over drill the hole and put the silver thread thingy in there thread it in there . It tightens perfect and will not hit the top deck
The silver thing i am talking about i do not know the name of but it is used on the top deck and the front bumper... Hope this helps..
Mike
I was planing on doing the same thing, but could not find a silver thread thing. I ordered a lower bumper since it has them in there, but it didnt come with any. Can you buy those seperate?
R.Dalnogare is offline   Reply With Quote
Old 05-14-2008, 02:03 PM   #2029
The old RDX lower bumpers did not have the threaded inserts, the screw just threaded into the plastic. The phi lower bumper comes with the inserts.
JoelV is offline   Reply With Quote
Old 05-14-2008, 03:41 PM   #2030
Korey Harbke's Avatar
The super short wheelbase is really cool. It really helps the car turn in and rotate well in all the low speed stuff. It hasn't shown any ill effects in the long sweeping corners either.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-14-2008, 04:57 PM   #2031
stiltskin's Avatar
Trader Rating: 102 (100%+)
I believe what you are looking for is the Aluminum insert nut, M3. Part number COR1255.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-14-2008, 06:08 PM   #2032
edseb's Avatar
Originally Posted by S.Bortolotti View Post
I have been practicing Modified for the Reedy Race, but the tempteratures up here in Canada have been quite cool from a seasonal standpoint which might feel like freezing for most of you! I have been practicing outdoors in weather that has been overcast and 50deg, and with only two days of constructive outdoor practice I have experimented with a lot of the stuff I have been reading about here and would like to share a few ideas with you guys.
I tried running the TA-05 diff in the rear, and it seems to work great. No better than the stock Corally diff, however it does seem to keep the dirt out and last longer resulting in fewer re-builds when running on sometimes dusty outdoor surfaces (that is the only reason I decided to make the switch).
As for getting the car to rotate better I have experimented with both the mid (stock) and the short (all shims behind the arm) and I found the car to work better through the middle and off the corner best with the stock wheelbase (with the longer wheelbase, there is more weight on the front wheels).
I'm running 1deg of sweep in the car aswell. I have met people who call this adjustment different names so I consider it/I put a 1mm shim behind the front, front hingepin coupler. This helps the car turn harder through the middle of the corner and really gets it to rotate better. Don't forget to re-adjust your toe-out on the front before you hit the track!
I have done away with sway-bars just because the grip here has been sufficient, but nothing spectacular. If the weather is decent this weekend I will try running the car with sway-bars and let you guys know how it goes.
I'm running 5-cell with the batteries forward, and the 2.5mm chassis. I will post a complete set-up when I get home from work, because typing all this up has gotten to be rather extensive!
Steve
In California, we are fortunate to be able to run year round. I had my car working really well with the couplers in the long position and shimmed short (yeah I tried all sorts of combos of toe/shimming/ etc.), but when we switched to the Reedy handout, then rotation really became an issue and a bad push mid to exit became big. After switching the car over to the shorter couplers it helped, but with everything else it was subtle. Now we've tried springing up to stiffer springs and even trying shimming the arms to make even shorter which seems to help. The Sorex 36 premounts don't seem to respond the way the RP30s did, but they do give lots of traction.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-14-2008, 07:41 PM   #2033
black-knight's Avatar
R/C Tech Charter Subscriber
-Korey
what parts do i need to run super short? short belt and optional bearing holders?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 05-15-2008, 01:16 AM   #2034
Holmenkollen's Avatar
If you run 36/18 pulleys you just have to get 415 front and rear belt. No optional bearing holders.
I think you need more stuff with the std pulleys.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 05-15-2008, 06:09 AM   #2035
So here is the set-up I have been running. It works great through the middle and off the corner, but it still lacks steering getting into the corner. However it should still be a good starting point at most tracks. I ran Sorex 28R's because the weather is still to cool for 36R's. As I said earlier I would like to try dropping the front and rear spring rate and putting the 1.3mm anti-roll bars on the car (Front to Tamiya Blue and Rear to 17 - Tamiya Blue is somewhere between 17 and 20 I find and is longer which makes for less pre-load).
FRONT:
Caster: 4 deg
Toe-Out: 0.5 deg
Camber: -1.5
Ride Height: 5mm
Wishbone: 35
Wheelbase: Short
F Coupler: Dot up
R Coupler: Dot up
Downstops: 2.0 up
Anti-roll bar: none
Front Width: 187mm
Front Drive: Spool
Front Pulley: 42T
Steering: stock
F Coupler shims: 1.0mm
R Coupler shims: 0mm
Oil: 40wt
Piston: 3-hole Tamiya
Rebound: 50%
Spring: 20lbs
Shock Tower: Stock
Steering Block: Narrow
Coupler Clamp: Stock
Clamp Shims: None
Shock Position: Inside hole on arm and tower (laid down)
Steering Link: Inside hole of knuckle
Camber Link: Low and inside
REAR:
Anti-squat: None
Toe-in: 2.0 deg
Camber: -1.5 deg
Ride Height: 5mm
Wishbone: 35
Wheelbase: Mid
F Coupler: Dot Down
R Coupler: Dot Down
Downstops: 2.5 up
Anti-roll bar: none
Rear Width: 189mm
Center Pulley: 21T
Rear Pulley: 42T
F Coupler Shims: 0mm
R Coupler Shims: 0mm
Oil: 35wt
Rebound: 50%
Spring: Tamiya Blue
Shock Tower: Stock
Upright: 0 toe-in
Clamp Shims: none
Shock Position: inside hole on tower, middle on arm
Camber Link: Outside hole on upright, down and inside on shock tower
Upright: Mounted in outside hole on arm
OTHERS
Tires: Sorex 28R
Motor: 3.5
Ratio: 8.6 Final Drive
Tire Additive: Buggy Grip & Tire Tweak
Spur: 104
Body: Mazdaspeed 6
Wing: Stock, mounted as far back as possible
Lead Weights: 14g in-front of batteries, 7g beside receiver, rest to make weight behind batteries
Notes: Tamiya Shocks, batteries forward, tire warmers set at 60deg for 20min with tire tweak, smooth surface, cold weather, medium grip
If you have any questions or I missed something I will be glad to help/fill you in
Steve
Steve Bortolotti
Old 05-15-2008, 11:56 PM   #2036
B4james's Avatar
Just finished building up my PHI, I will be running 27 turn stock and wanting to know if it is possible to run without the belt tensioner on to reduce drag or will there be belt issues ?
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 05-16-2008, 12:05 AM   #2037
I have never actually used the belt tensioner, in all classes of racing
Old 05-16-2008, 11:15 AM   #2038
edseb's Avatar
As Korey said you probably don't need the belt tensioner in stock and definitely won't use it if you change to the short coupler wheelbase conversion. With such large pulleys, it shouldn't really be an issue.
Carl Hyndman
Old 05-16-2008, 12:51 PM   #2039
Thanks, I will give it a try this weekend.
Steve Bortolotti
Old 05-16-2008, 01:19 PM   #2040
Jeff Brown's Avatar
Originally Posted by Still Bill View Post
And removing that center brace sure helped me avoid chassis tweek issues on my asphalt car. Will try doing it during carpet season too.
Hey Bill,
I heard you called yesterday about the short wheelbase. I built my new car with it. The only items needed would be the 36T pulleys and a Tamiya belt. The part number for the belt is TAM53707. It will allow you to run the coupler clamps in the short position with the 1.71 drive ratio. You just flip over the diff holders.
It will also allow you to put the shocktower on the frontside of the rear mount to help with shock angle.
Also, I am running the narrowed knuckles on the front. I took the rear arms and dremeled them out to accept the C-hubs. You put the C-hub in the outside position of the arm. I also use the optional two hole rear hubs and run the hingepin in the outside hole as well. You will need no shims on the front end if you use the rear arms.
Jeff
Jeff Brown is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
