Old 03-15-2008, 09:56 PM   #1831
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
thanks
R.Dalnogare is offline   Reply With Quote
Old 03-16-2008, 12:30 AM   #1832
ottoman's Avatar
R/C Tech Charter Subscriber
Looks like you guys will have to listen when Josh H gives advice here.... he TQ'd 13.5 rubber at the ROAR nats by one full lap over second place
Now thats domination by the DR.
ottoman is offline   Reply With Quote
Old 03-16-2008, 11:10 AM   #1833
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Hey Guys I am selling a PHI if anyone is interested built by the man..
http://www.rctech.net/forum/showthread.php?t=209860
HRCRACER123 is offline   Reply With Quote
Old 03-17-2008, 08:20 PM   #1834
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Congrats to everyone on the team for their runs at the carpet nats. Lots of bad luck going around but everyone kept their head up and worked hard.
Congrats to Josh and Brian for their rubber tire runs. Not bad for some year old 13.5s.
Thanks Mike Blackstock for the laughs, and the lessons on the correct way to tape the batteries in your 12th scale lol
Thanks Robbie and Jeff for everything, and Larry for all your help getting my 12th scale setup.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 03-17-2008, 08:23 PM   #1835
Trader Rating: 15 (100%+)
James i lost it myself ,,but at least im not number two.
AARON YOUNG is offline   Reply With Quote
Old 03-17-2008, 09:37 PM   #1836
rosko's Avatar
ANYONE HAVE ANY NEWS ON THE CEFX PHI LI-PO CHASSIS?
rosko is offline   Reply With Quote
Old 03-18-2008, 12:38 AM   #1837
rosko's Avatar
it seems like most of this thread is about crappy diffs and li-pos not fitting. hopefully corally can come up with a diff fix on that issue and update the kits instead of well, buy this and that and youll be ok . and mr. josh the mad scientist can hook us up with his great inventions on the li-pos. you the man josh.
Old 03-18-2008, 06:30 AM   #1838
I don't get the diff problems. They are very easy to build and smooth as can be. You just have to take care of them. Clean them once in awhile.
Old 03-18-2008, 06:49 PM   #1839
Trader Rating: 26 (100%+)
david-the diffs are horrible.if you run on carpet then you will experience after 2to 3 runs there gritty as hell,still no fix and thats poor service considering the rest of the car is top notch!
eddie10 is offline   Reply With Quote
Old 03-18-2008, 06:57 PM   #1840
~McSmooth~'s Avatar
Have you tried replacing the thrust bearing with the 1/12 diff spacer (part # 75296)?
You also replace the 1/4x3/8 unflanged bearing with a 1/4x3/8 flanged bearing. But you install it from "other" side of the outdrive instead.
i.e. The old unflanged bearing goes in the "diff ring" side...the new flanged bearing goes in through the "diff nut" side.
You use the same cone "belleville" washer and diff nut. You're basically making the diff work like a 1/12 scale.
I'm sure this mod has been covered somewhere else in this thread.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 03-18-2008, 06:57 PM   #1841
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Eddie, I just ran all week @ the carpet nats w/out rebuilding the diff. I have changed out the thrust bearing to use the 12x washer.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 03-18-2008, 06:57 PM   #1842
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Well beings that I raced with him at the nats this last week I'd say he ran on carpet... Unless there was somthing I was clearly missing... Could of been what I was doing wrong all weekend lol .. I have no problems with the diffs either, but oh well.
I just can't wait to see Josh's setup.. So i can see why I sucked so badly
Dustin Layne
smoke81 is offline   Reply With Quote
Old 03-18-2008, 07:45 PM   #1843
Yeah I was kinda on carpet for a week too. Never touched my diff. Replace the thrust with the 12x spacer and your money.
And if I were yall, I'd be asking to see that Stanton guys setup too. He seemed pretty fast
Old 03-18-2008, 08:40 PM   #1844
Trader Rating: 1 (67%+)
If your only getting 2-3 runs out of your diffs I think you might have a setup problem. If you constantly unload 1 of the rear tires it will trash your diff.
I went all week on 1 rebuild........and that was just from boredom.
Stanton, Dave, Juan and myself all ran my novak setup with a small change in toe and droop on Brians car
Josh Hohnstein is offline   Reply With Quote
Old 03-18-2008, 08:50 PM   #1845
Nats setup was same as novak with 2 changes
55wt front oil
no shim under front blocks
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
