Old 03-01-2008, 08:39 PM   #1771
Still Bill's Avatar
Originally Posted by imber View Post
what turnbuckle sizes are you guys using to use the outer holes on the shock towers?are they the 28mm?
The smallest in the Corally parts...think it is 22mm.
Oops! BJ is right. 28mm is the correct length. My bad!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-02-2008, 09:38 AM   #1772
BJohnson's Avatar
22mm is for the steering linkage from the servo. The 28mm turnbuckles are the shortest that you need in order to run the outer holes on the shock tower.
BJohnson is offline   Reply With Quote
Old 03-03-2008, 09:43 PM   #1773
Still Bill's Avatar
On Corally USA website...
02.06.2008
New items have arrived for the RDX Phi. We now have available narrowed aluminum steering knuckles, 79278A. In order to use these you must also purchase short axles, 79184A, and longer CVD Bones, 79182A.
The narrowed knuckles will shift the top camberlink farther out into the wheel for more steering. You will need to add 2 additional shims behind your roll mounts to widen car back to max width. We have tested these with great results on asphalt and carpet rubber tire.
Old 03-04-2008, 04:10 AM   #1774
stiltskin's Avatar
Trader Rating: 102 (100%+)
02.06.2008
I saw that too. Da#$ them! Why do they have to keep improving their cars?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-04-2008, 10:08 AM   #1775
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
02.06.2008
Did someone say more steering?
JamesArluck is offline   Reply With Quote
Old 03-04-2008, 12:21 PM   #1776
crunchracer's Avatar
Korey any good news about the CEFX Chassis?
www.FusionMotorsports.com
Team S.I.R
John's BSR Racing Tires
crunchracer is offline   Reply With Quote
Old 03-04-2008, 07:15 PM   #1777
Still Bill's Avatar
It should have come out for the original RDX...
Jeff, Will these parts be available at the Carpet Nats?
Old 03-05-2008, 08:46 AM   #1778
Jeff Brown's Avatar
Well, I do not think I have sent them to the Hobbytown yet. I will check with them and should be able to get them out to the shop.
Jeff
Jeff Brown is offline   Reply With Quote
Old 03-05-2008, 05:04 PM   #1779
Korey Harbke's Avatar
Well, after about.... 30 packs or so on the CEFX chassis, I've concluded it won't yeild any real benefits untill the traction is REALLY high. So far at SIR, there isnt a real need for it, it tends to make the car push more than the stock chassis. I just put the stock chassis on and I was faster considering our track layout is so tight right now.
I didn't really care for the shock towers much, I prefered the positions available in the stock kit. The CEFX shock towers have slightly different positions for both the shock positions and the camber link positions are a little weird in my opinion. I do know the rear shock tower was designed around some slightly different rear hubs, so the camber link positions are not quite optimized if you are using the stock parts. There may be a time where these parts would work well, but not in my situation.
The one cool thing I did try is the ackerman extension. I did notice it produces more low speed steering in tight 180's.
But in the end... Most of the stock parts that come on the car have yeilded better results for me. Just goes to show you the Phi is really great out of the box.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-05-2008, 08:17 PM   #1780
Still Bill's Avatar
Thanks for the report Korey.
Have you tried the new narrow steering parts yet? Not that you really had the time...LOL
Old 03-05-2008, 09:25 PM   #1781
Uhhh they've been floating around the team for a little while, but I havent tried them yet. I'll be giving them a shot here in the next two weeks probably. I just sold my Raptor 50... so I have some extra spending $$$$$ for parts and such . I think it's time for some new chargers... hahaha
-Korey
Old 03-06-2008, 09:33 PM   #1782
Still Bill's Avatar
From the Corally website: "The narrowed knuckles will shift the top camberlink farther out into the wheel for more steering. You will need to add 2 additional shims behind your roll mounts to widen car back to max width. We have tested these with great results on asphalt and carpet rubber tire."
Jeff,
The above makes me believe that I am supposed to bring the car back to max width after installing the new hardware.
Has anyone tried leaving the car fairly narrow with the new hardware for quicker reaction? Or, is it just 'over the top' that way? Thanks.
Old 03-06-2008, 09:42 PM   #1783
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
How about with narrow wheel hex's aswell?
Dustin Layne
smoke81 is offline   Reply With Quote
Old 03-06-2008, 09:48 PM   #1784
Still Bill's Avatar
Thanks, I was thinking narrow hexes for the rear too.
Old 03-07-2008, 07:03 AM   #1785
overall, a narrow front will give you more steering. narrow wheel hexes will in a round about way alter your ackerman affect slightly as well.
if your rear is more narrow than your front, you will experience understeer.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
