Old 02-27-2008, 11:56 AM   #1756
Korey Harbke's Avatar
Originally Posted by edseb View Post
I also have to take in to account my caster blocks and the fact that I run kick up in my asphalt car. These two combined will put the ball stud on the steering block even lower increasing bump. Guess its just some trial and error for me.
Yeah, thats a bummer. Let us know what you find! I'm going to be running more asphalt/rubber tires here soon so I'm sure that will come up in the process.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-27-2008, 01:21 PM   #1757
Any ideas on a target gear ratio for a brushed stock motor with lipo on a short track on rubber?
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 02-27-2008, 01:31 PM   #1758
Can you be more specific to which stock motor and if you are running foam (and what dia) or rubber tires?
-Korey
Old 02-27-2008, 01:52 PM   #1759
rubber tires, and a putnam binary quad mag. I haven't run stock in 10 years or so but I probably want to be slightly over geared and I'll just drive to keep the momentum up.
Old 02-27-2008, 01:54 PM   #1760
Ok... so these were a really high rpm motor... try around a 8.5 final drive ratio. That should get you somewhere in the ballpark.
-Korey
Old 02-27-2008, 05:57 PM   #1761
-Korey
Excellent, thanks.. gear ratios have changed a lot and I probably wouldn't have even tried 8.5, the last time I raced anything electric was at the 2004 nationals with a 10 turn and a half prototype yokomo.. I thought about running that car, but the corally is sooooooooo much better in every way.. You guys have it easy these days especially with brushless and lipo.
Old 02-28-2008, 07:37 AM   #1762
Red face Body Posts
I'm new to racing and have a PHI, I'm having trouble with the threaded body posts. My Recoil and TAO5 both have the "pin-type" body posts that seem a lot easier to deal with. I didn't see any pin-type posts on the Corally site. Can some one tell me:
1) If I can get pin-type body posts for my PHI, or
2) Hints on using the threaded posts that I have. They are slow and take more work than using the body pins.
Thanks, from a NooB
Chinewbie is offline   Reply With Quote
Old 02-28-2008, 08:14 AM   #1763
imprsme's Avatar
Trader Rating: 74 (99%+)
Thanks, from a NooB
You can replace the thread type with pin type. Just get some HPI or Xray "FRONT" mount kits and you will be fine.
The trick to the thread type is to cut them short! Cut the post just tall enough that you only have to thread the top on maybe 5-6 turns. The more you use them the easier they get thread on.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 02-28-2008, 09:03 AM   #1764
Smile Body posts
Thanks Imprsme. I will hunt down the pin type as well as cutting down the threaded posts that I have.
Old 02-28-2008, 09:26 PM   #1765
Still Bill's Avatar
I prefer the HPI 16507 body posts. They come packaged in pairs at about $3.50 a set.
The other thing I do is add a fifth body post at the front hole in the top deck. For that fifth post, I do use a cutdown Corally post and nut. This allows you to adjust the fifth post height with the nut. Placement of this post stops your body from flexing downward just ahead of the windshield which saves you from getting those nasty cracks at the tops of the front wheel wells. It is a old Matt Francis (sorry Matt) trick that makes a lot of sense to me because my car bodies last longer.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-01-2008, 01:42 AM   #1766
MikeR's Avatar
Trader Rating: 15 (100%+)
Any one have an extra RDX alloy steering lever they want to sell? I've looked all over superiors and stormers website and coming up empty. Maybe someone has a link to it
Much Thanks
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-01-2008, 11:34 AM   #1767
MadBrushRacing's Avatar
Hi
Can anyone tell me wha Lb springs come in the black spring kit?
Also what are the part numbers for the shims that change te rear toe in and the ones that adjust the width?
Tony
MadBrushRacing is offline   Reply With Quote
Old 03-01-2008, 12:47 PM   #1768
Hi
Tony
Old 03-01-2008, 04:42 PM   #1769
ooliganRC's Avatar
Send a message via MSN to ooliganRC
Originally Posted by MadBrushRacing View Post
Hi
Tony
springs are the ones you need for TC tony .. i know a 14, 19 22 and 25 are in there
ones for toe and width are the same :P
no idea on part number i just borrow rob fox's :P
P
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 03-01-2008, 08:28 PM   #1770
Default rdx
what turnbuckle sizes are you guys using to use the outer holes on the shock towers?are they the 28mm?
imber is offline   Reply With Quote
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
