Old 02-24-2008, 07:26 AM   #1726
29TC's Avatar
Send a message via ICQ to 29TC
Hey guys, where can I get substitute 'trust bearing CONE WASHERS'?
I don't think Corally sells them separately. I have broken 3 of these washers already. And every time i have to buy the diff rebuild kit just for the cone washers.
So, where can i find replacement cone washers?
By the way, anyone having the same problem?
Thanks.
29TC is offline   Reply With Quote
Old 02-24-2008, 09:42 AM   #1727
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Thanks.
You're the first I've heard of to have that problem. Are you tightening the diff way too much and breaking them? I can't see any other way that would be happening.
As far as I know, you can only get the cone washers in the rebuild kit. Jeff Brown may know better, though.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-25-2008, 04:15 AM   #1728
Default Diff Modification
Hi all,
can anyone of u make some pcitures of the DiffModification with an 1/4" x 3/8" flanged bearing ???
Or please explain it step by step, it would be helpful and more easy to read it in one Post and not in 3-4 Posts.
Thanks,
Marcel
BlueSilver is offline   Reply With Quote
Old 02-25-2008, 05:48 AM   #1729
29TC's Avatar
I figured I might have tighten it too much on my 1st two washers, but only the rear diff I am having this problem. Front diff is ok.
So, I looked at corally web and download the latest phi manual. Now the diffs do not use those cone washers! Is the manual correct? Can I do without that cone washer??
Guys with the lastest PHI, is the diff using cone washers between the M7 nut and trust bearing?
Old 02-25-2008, 06:31 AM   #1730
You will still need the cone washer. The original manual forgot it, and it seems the one on the website still hasn't been upgraded.
The flanged bearing diff mod:
Take one of the unflanged bearings out that goes on the long shaft. Instead of the thrust bearing stack, take the flanged bearing and put it where that was facing down into the short diff shaft. Then on top of the bearing you need a couple of shims (the ones that would shim a 12th associated axle part#4554) then the cone washer and finally the diff nut.
JoelV is offline   Reply With Quote
Old 02-25-2008, 06:36 AM   #1731
imprsme's Avatar
Trader Rating: 74 (99%+)
Originally Posted by BlueSilver View Post
Hi all,
Thanks,
Marcel
Its very simple.
when rebuilding the diff.
do not put the thrust washers,Thrust cage, and the bearing that goes on the "diff ring" side of the diff half bearing back in, substitute them with the diff spacer (part #COR75926) and a 1/4"x3/8" flanged bearing.
inside the thrust side diff half. Put the Flanged bearing in the place of the "normal" bearing you discarded earlier.
Then place the Diff spacer on top of that Beveled side towards the bearing
Next place the cone washer on top of that (Just as the instructions show)
Then on top of that put the diff adjustment nut.
Build the diff as normal from there.
Hope this is easy to understand..it easier to do then to type it out..LOL
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 02-25-2008, 08:04 AM   #1732
29TC's Avatar
On the manual included in my Phi, there is a part number 75924 for the cone washer. After some searching I found this :-
https://www.ssl-stormerhobbies.com/c...ns&pn=COR75924
Is the SPX12 diff nut similar to the phi M7 nut? And do you think that "grooved" cone washer will work? Its cheaper than buying a phi diff rebuild kit.
Old 02-25-2008, 01:53 PM   #1733
Swamp Rat's Avatar
Originally Posted by Brian Bosley View Post
Where do you guys pack on all the weight to run lipo?
I needed 160 grams on the battery side just to balance the car.
If you run Flat bottomed Lipo (no humps)
fill in the battery slots with lead. Place the chassis on a flat heatproof surface. Melt and pour the lead into the slots. trim flat to surface
I got 96 grams in there. only 64 to go.
LCRCCC. inc. The Greatest Club in QLD.
Come see our great new layout.
Schumacher Mi6 x 2,Yokomo BD7, Roche F1, SP F1 x2,Serpent SF2 F1, MO5 mini, M03 Mini, Corally F1 on Rubber, Futaba 4PX,
Ax10, SCX10, Joker Visit : www.lcrccc.org.au
Swamp Rat is offline   Reply With Quote
Old 02-26-2008, 11:12 AM   #1734
edseb's Avatar
Been having trouble totally eliminating the bump steer on the steering. I've tried some washers under the steering below deck, but with 2mm shimmed and some other ones I still get it, if anyone can save me a lot of troubleshooting it would be great. I've heard it is significantly more?
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 02-26-2008, 03:10 PM   #1735
edseb's Avatar
TTT
Carl Hyndman
Old 02-26-2008, 03:26 PM   #1736
USVTA Member #211
Old 02-26-2008, 03:26 PM   #1737
To reduce bump steer, you have to put shims under the steering knuckle ball studs. Use as many shims as required to make the steering links parallel or slightly below parallel (angled down to the outside) to the ground at ride height.
USVTA Member #211
Old 02-26-2008, 03:27 PM   #1738
Korey Harbke's Avatar
I havent really had any problems with the bump steer. I honestly have really even noticed it. It's nothing like the old car, but I'm running foam tires, so the geometry is a little different and the suspension won't travel as much to actually SEE the bump steer.
Which way is it bumping? I'm not sure any of the other guys are really messing with bump steer. Maybe Jeff can hop on here and give some insight on this.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-26-2008, 03:32 PM   #1739
stiltskin's Avatar
Trader Rating: 102 (100%+)
I had a problem with bump steer this past weekend. I bumped the car in front of me and steered right into the da#$ wall.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-26-2008, 03:38 PM   #1740
Ha... dont you hate that kind of "bump" steer?
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
