Old 02-19-2008, 08:56 PM   #1711
Still Bill's Avatar
Thanks Korey...As usual!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-20-2008, 09:31 AM   #1712
1fastdude's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Still Bill View Post
Right now I have the Futaba 9550 servo in my Phi cars. But, I was looking for a bit more speed and torque; so, I bought a JR DZ9000S to try. Only problem is that it does not fit.
What part does not fit? I have the new 9100S JR servo in my Phi and I do not have any problems!
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 02-20-2008, 08:53 PM   #1713
Still Bill's Avatar
The front end of the DZ9000S with the servo saver is 1/16-1/8" into the top deck when mounted. I would have to hack away quite a bit from the top deck to make it fit. The 9000 is supposed to have special gears. Maybe that is why it sticks out towards the front so much.
Thanks for letting me know about the 9100S. That may be an option; but, the Futaba BLS451 may win out too.
Thanks.
Old 02-21-2008, 02:11 AM   #1714
Thanks.
Bill, why don't you just add a 2 or 3mm spacer between the servo mount and the servo?
Juan Aveytia is offline   Reply With Quote
Old 02-21-2008, 07:16 AM   #1715
Where do you guys pack on all the weight to run lipo?
I needed 160 grams on the battery side just to balance the car.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 02-22-2008, 06:56 PM   #1716
Trader Rating: 36 (100%+)
How do you know whether you have the fine threaded or regular threaded diff nuts?
I need to order more and don't know which I have.
EVILGRAFX is offline   Reply With Quote
Old 02-22-2008, 07:05 PM   #1717
stiltskin's Avatar
Trader Rating: 102 (100%+)
The newer kits had the upgrade. You should have the fine threads.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-22-2008, 07:18 PM   #1718
Tony,
That's what I figured but, looking at these makes me wonder. They don't look very fine.
Old 02-22-2008, 08:14 PM   #1719
jbb
what page was that ultimate rubber carpet setup on?
thanks
jbb is offline   Reply With Quote
Old 02-22-2008, 08:50 PM   #1720
Still Bill's Avatar
thanks
If you are running stock (up to the 13.5), the ultimate rubber carpet setup is Rob Michael's from 2007 IIC.
Old 02-23-2008, 07:47 PM   #1721
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
Whats the difference between the silver and black spring kit?
R.Dalnogare is offline   Reply With Quote
Old 02-23-2008, 08:07 PM   #1722
Still Bill's Avatar
The black spring set contains the softer springs and the silver has the heavier.
For all my rubber setups, I only use conbinations of the black springs; so, I would not recommend buying the silver set for rubber. Silver springs may apply to some foam setups though.
Old 02-23-2008, 08:16 PM   #1723
perfect, thanks
Old 02-24-2008, 01:10 AM   #1724
SSUPERSTARR's Avatar
The older threads are flatter, not as deep. The newer threads are sharper, more pronounced. If you have the newer threads you would have to add an "A" to the end of the part number.
SSUPERSTARR is offline   Reply With Quote
Old 02-24-2008, 06:21 AM   #1725
Thanks for the info, I know which diffs I have now.
team corally rdx phi A.Galenski R/C Items: For Sale/Trade 6 05-28-2008 06:22 PM
Team Corally RDX TWISTED Australia For Sale/Trade 7 02-05-2007 04:34 PM
Team Corally RDX Bear55 R/C Items: For Sale/Trade 4 10-10-2006 03:18 PM
Team Corally Assassin 1449 R/C Items: For Sale/Trade 0 10-20-2003 11:27 AM
