Old 12-07-2006, 10:11 PM   #16
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by DR VOODOO
THE LIGHTNIG I WOULD NOT USE AS A PAPER WEIGHT!
This is something I actually agree on you with 100%!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 12-08-2006, 03:00 AM   #17
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Originally Posted by Glowster21
I had a DPD and it was great. Only reason I got rid of it was because it did not have voltage hold.
So the DPD keeps dumping the 1-5th cell before the 6th one? or does teh DPD hold it at like... .9 volt per cell like the Smart Tray?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 12-08-2006, 04:01 AM   #18
Trader Rating: 44 (100%+)
i've not seen my DPD dumping the 1st~5th cells... even if the 6th cell takes a while to drop to the cutoff voltage.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 12-08-2006, 04:34 AM   #19
wallyedmonds's Avatar
the novak smart tray dos not hold the volts at .9 a cell it discharges with alot less A so the cells stay lower longer than if you discharged with a 30 or 5 a cell discharger.
wallyedmonds is offline   Reply With Quote
Old 12-08-2006, 07:47 AM   #20
SlamMan's Avatar
EA
Dang! The price of the Lightning V2 is tempting and I was considering trying it out. What don't you guys like about it? What do you use Eric?
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 01-02-2007, 01:45 AM   #21
BSchorr's Avatar
TTT!
Old 01-02-2007, 02:19 AM   #22
MadMikeB's Avatar
I'm confused, why do you need to eq before charging? If the Lightning discharges every cell down to .9V (or whatever) surely that IS equalized? Or am I missing the point here?
Mike
Originally Posted by dodgeguy
I say go with the lightning V2. It is the most cost effective unit. Really all you need is a something to dump your packs fast. Then equalize before charging. I am really looking into getting a lightning and unloading my CTX-D.
MadMikeB is offline   Reply With Quote
Old 01-02-2007, 03:53 AM   #23
Veteq's Avatar
I prefer the CTX-D2 for the following reasons. I run mod so I can use the discharge time after my run to gauge my power usage and see if I can gear up or not. Also like most said it discharges each cell individually. Also it's very versitile in the fact that the discharge cut-offs voltages are adjustable.
For me if you have the money go for the Much More unit. I have seen them them all and used the DPD the CTX-D and the CTX-D was better.
Team Associated - Reedy Motors - Team Much More
Slapmaster Tools - Apollo Hobbies - Hi Performance Distribution
Overgeared B.O.D - [email protected]
www.AEforums.co.uk
Veteq is offline   Reply With Quote
Old 01-02-2007, 04:04 AM   #24
proceed5's Avatar
MuchMore CTX-Dv2
proceed5 is offline   Reply With Quote
Old 01-02-2007, 05:00 AM   #25
thecrow2k's Avatar
Id just add a comment. A person further up said their MM came faulty, I knew someone who bought a CTX-D and had 3 turn up, all faulty until finally he got a working one....which then broke.
thecrow2k is offline   Reply With Quote
Old 01-02-2007, 06:18 AM   #26
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
The new "SE" version of the smart tray does hold the voltage.
XMSRacing is offline   Reply With Quote
Old 01-02-2007, 08:31 AM   #27
Trader Rating: 23 (100%+)
I had a DPD and it was great. Only reason I got rid of it was because it did not have voltage hold. I have seen the CTX-D version 2 in action and it is nice but I personally don't like screw posts. The best thing about the DPD was it did not require being connected to a Power Supply.
I thought the DPD did hold voltage.
bmcallister is offline   Reply With Quote
Old 01-02-2007, 08:58 AM   #28
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Mike
The get the best result out of your pack, it is always best to equalize the cells prior to charging, to ensure they get a even charge.
I have not used the Lightning, but do use the CTXD, but beleive they generaly work the same.
After pulsing the pack down to .9 per cell, most times the pack does not finish all cells at the same time, so they tend to "reset" themselves back to 1.2V or so. Once the pack has cooled (if after race), the CTXD will still take 4-6 minutes to equalize the cells to .9 @ 5A linear. Once equalized for the first time, I generally run the linear discharge again, and then will charge the pack.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 01-02-2007, 01:07 PM   #29
Trader Rating: 198 (100%+)
Mike
each cell has its own discharge curve. and charge curve. i have a CTX-D and a ICC. From these units I can see how the cells are not all the same. The matchers use discharge curves to grade cells. Not peak charge time or volts. This way of charge matching along with discharge would give us all great pack. But this way would also take more time to grade into packs.
Since we use mV drop off to peak a pack. If a cell is over charged and on is under you will still have an undercharged cell. and the pack will not be as strong during the race.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 01-02-2007, 02:14 PM   #30
yes true i just seen this,but really what will this do for the batts anyway.
muchmore, trinity, and integy discharge trays Dave Bowser R/C Items: For Sale/Trade 10 08-04-2008 05:09 PM
F/S Muchmore CTXD2, Integy 0-30 Reactor, Trinity D90 Dasupacat1 R/C Items: For Sale/Trade 5 11-03-2007 10:48 AM
Trinity DPD VS. Teamwave Lightning discharge Equalizing System Jochim_18 Electric On-Road 58 07-25-2007 07:54 AM
Muchmore,Trinity stuff dougmartin R/C Items: For Sale/Trade 8 04-27-2007 02:41 PM
Dischargers MuchMore, Trinity Anemic_SluG R/C Items: For Sale/Trade 5 12-11-2006 05:32 AM
