Old 02-24-2003, 06:38 PM   #1
unknown's Avatar
Send a message via AIM to unknown
Default Fixed flipping problem - now I need more steering
I posted last week about having problems with my car flipping when going into turns at high speed. I fixed that...but now more than ever when I am turning...the car seems to always want to go wide. I see everyone else taking turns and they turn on a dime. My car just seems to always wanna make a huge circle turn. What is the deal?
unknown is offline   Reply With Quote
Old 02-24-2003, 06:52 PM   #2
popsracer's Avatar
Default Now I need more steering
Unknown;
The term is called "Understeer" in the Front (or Push). It means you have less grip in the Front than you do in the back.
How about posting your Car and Set-up so we can have more information to help you better.
popsracer is offline   Reply With Quote
Old 02-24-2003, 07:30 PM   #3
unknown's Avatar
FRONT -
springs = copper
shock oil = 40 wt.
sway bar
double purple foams
REAR
springs = red
shock oil = 40 wt.
sway bar
purple foams
the droop is set to stock. that is either 4 in the rear and 6 in the front...or the opposite of that. I forgot. I am not by my car right now. IF you need anymore info...let me know.
Old 02-24-2003, 08:05 PM   #4
popsracer's Avatar
Default now I need more steering
Try some heavier shock oil in the Front 45wt and using the same compound tire Front and Rear.
I don't think I remember what kind of Car you have.
Old 02-24-2003, 08:09 PM   #5
Korey Harbke's Avatar
It was a tc3 I think
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-24-2003, 08:25 PM   #6
I'm not sure what car you use, but I'd start with some plaid front tires. (purple with an orange outer ring so it can't fold under) Also, 40wt oil might be a little light for foam tires, but that kinda depends on what pistons you use. I think people could help you out alot more if you posted your entire setup with shock locations, camber link settings, caster, camber, tow, etc....
JeffC is offline   Reply With Quote
Old 02-24-2003, 09:12 PM   #7
wheelmanST's Avatar
Send a message via AIM to wheelmanST
run the setup i gave you!
70/50 oil with swaybars front and rear and same springs....you will love it.
wheelmanST is offline   Reply With Quote
Old 02-25-2003, 03:56 PM   #8
unknown's Avatar
Default here are the pics
FRONT 1
FRONT 2
TOP VIEW OF FRONT
REAR
REAR TOP VIEW
SIDE VIEW
Please note: In the pictures, I have the red springs on the front and the copper springs on the rear. That was just a test...and the real setup I was running was red in the rear and copper in the front.
Old 02-25-2003, 03:57 PM   #9
wheelmanST's Avatar
ok well go to the F-0 block up front....and maybe lean the top of the shocks in one hole in the front...should give you more bite and steering
Old 02-25-2003, 06:37 PM   #10
unknown's Avatar
popsracer...what do you have to say about the setup?
Old 02-25-2003, 08:23 PM   #11
popsracer's Avatar
Default unknown;
I really wish I could give you some better answers than I already have, but I am not familiar with the handling traits of the TC3. All I can do is give some general recommendations that should apply to all R/C Cars.
I ALWAYS run the same Compound tire and insert Front to Back. In my opinion, It is much, much easier to set-up and tune a chassis this way.
Try not to get too far apart Front to Rear with the Spring rates and Shock oil weights. I usually run no more than a 10wt difference from the Front to Rear.
Your car will almost always be much easier to drive and tune if the front and rear "Rates" are closer to each other. What I call a "Balanced" set-up.
Get to know your Car well, make ONE change at a time so it can be evaluated properly. You need to know what works and what doesn't.
I'm sure that there will be plenty of people that will disagree with my statements. But it has always worked well for me.
I also recommend a hop over to the TC3 thread, as the people there have alot more experience with the Car than I do.
Old 02-25-2003, 08:36 PM   #12
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Pops, he's running foams, you don't run the same tires front and back. Here I'm going to give you a good setup, all the fast tc3 drivers at my track run it.
Front:
70 oil
Purple spring
2 piston
swaybar
Plaid Foams
Rear:
60 oil
copper spring
2 piston
swaybar
Purple foams
Low roll-center all around (inner camber holes most upper and inner), and shocks stood all the way up front and rear. Make sure you have enough droop, too, try 4 in front and 3 rear (depends on tire size).
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-25-2003, 08:50 PM   #13
popsracer's Avatar
Default Pops, he's running foams
Sorry I missed that.
Never ran Foams on my Electric Car.
For Nitro racing on parking lot tracks I use what ever compound Foam works F/R. For Big Permanent tracks , I try to run the same compounds F/R. Usually this works well and gives me more even tire wear.
Old 02-25-2003, 09:32 PM   #14
unknown's Avatar
thanks for the help everyone! I am going to print out this whole thread and take it to the track. I will do one thing at a time. Eventually...I will get it right.
Old 02-25-2003, 09:51 PM   #15
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Actually Axiom 5B you are not correct. If he is running dprp/prp it is ok to try dprp/dprp. It's not uncommon for foam carpet racers to use double purples in the front and rear if the track has tons of traction. Sometimes it's the only way to get the car to rotate.
Where do you race Axiom 5B? What's your local track? And who are you if you don't mind me asking?
BigDogRacing is offline   Reply With Quote
TC4 steering problem mnapp69 Electric On-Road 4 12-25-2007 05:20 AM
small problem, probebly easily fixed kwik-kid R/C Tech Site Forum 3 10-29-2007 05:59 AM
how to fix the problem in steering? Potter Micro and Mini Scales 2 10-18-2007 06:19 PM
Steering Problem jmdv Nitro Off-Road 8 06-28-2007 08:23 AM
