Old 12-03-2006, 04:46 PM   #1
RCpurplecow's Avatar
Default One way or Spool
What is the difference between a one way and a spool? I know a one way gives more corner speed, but what is a spool and what are the benefits of a spool? What track conditions are a spool best on?
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 12-03-2006, 05:06 PM   #2
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Read this forum (see below). You should get your answer there...
http://www.rctech.net/forum/showthre...t=oneway+spool
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-03-2006, 05:06 PM   #3
juanfinesse's Avatar
well, a spool rhymes with pool so i guess it should give your car more underwater speed. Get a one-way i already told u KEMAL.
juanfinesse is offline   Reply With Quote
Old 12-03-2006, 05:10 PM   #4
protc3's Avatar
for most track conditions a spool is the choice for asphalt racing.a oneway is good for a real fast sweeping high traction track.you can get a oneway to work well but it is usually a handfull if the car setup is off.if you get a spool car set up correctly you will be faster on most all normal somewhat tight track layouts.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-03-2006, 05:19 PM   #5
spools break ur car (so do pools)
Old 12-03-2006, 06:20 PM   #6
protc3's Avatar
pipes make spools break your car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-03-2006, 08:53 PM   #7
Send a message via AIM to R/C Anonymous
My spool ran AWESOME in my JRXS when I had it dialed in. Never tried it on any other car.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-04-2006, 05:40 AM   #8
Skiddins's Avatar
If you want to try the effect of a spool, just tighten the diff right up so it virtually becomes spool.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-04-2006, 06:09 AM   #9
I am running a one-way diff and a rear ball diff on my cyclone S. Cornering is so much more smoother with the one-way than the spool. However, when I brake on the straight, my car spins. Is my car tweaked? or is it due to the one-way diff? BTW, I am not running the one-way pulley.
Karmon is offline   Reply With Quote
Old 12-04-2006, 06:39 AM   #10
dawgmeat's Avatar
turn down your EPA setting fot the brake on your radio to about 30-40%
dawgmeat is offline   Reply With Quote
Old 12-04-2006, 06:39 AM   #11
dawgmeat's Avatar
Old 12-04-2006, 06:41 AM   #12
Racingbod85's Avatar
Witha one way you have no front brakes - so the trick is don't brake! the back end locks and throws you off - as you found. you let the motor braking slow the car or have a very small amount of braking availabl and use it at low speeds to get the car round hairpins quick. you'll find it helps you turn in very well off power as the backend slows and tucks the car in.
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
TF-5 Spool VoneSkip Australia Wanted to Buy 0 04-22-2007 03:45 AM
Spool set up JL Electric On-Road 11 04-03-2006 12:49 AM
New Alm Spool for HPI Pro 4 topgluer Electric On-Road 4 09-08-2005 01:00 AM
Spool propain Nitro On-Road 9 03-14-2005 08:33 AM
what's a spool? rcnewb2004 Electric On-Road 21 12-05-2004 10:54 AM
