Old 02-24-2003, 03:16 PM   #1
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Rechargable M8 Battery Pack?
I am tired of changing out the batteries on my m8 every couple of days and want to get some rechargables for it. It looks like the pack airtronics makes is around 70 bucks and that is kinda rediculous. I noticed the charging jack on the bottom of the m8 battery tray, have any of you just purchased some individual rechargable cells, bought a male plug to fit the jack and used a regular charger to charge the whole tray/pack?
Blake
Blakesrc is offline   Reply With Quote
Old 02-24-2003, 03:30 PM   #2
che
che's Avatar
I have purchased rechargable akalines for mine last year.
They came as a package with the fast charger (8 cell charger).
The great thing about this solution, is it is less expensive,
you can charge them over 100x easily and they are 1.5v instead of 1.2v for the nicads or nimh, so it is stornger.
Works great and I can go at least 2 race days without having to recharge.
che is offline   Reply With Quote
Old 02-25-2003, 05:23 AM   #3
WVRACER's Avatar
Send a message via AIM to WVRACER
airteonics makes a trickel charger that has a corde for that tray and a recever pack it is cheap and works well. you can get som 1200 of 1500 aa cells and have great power on you m8
plus for the price of the seald pack you could put together 3 normal trays with rechargable
later wvracer
WVRACER is offline   Reply With Quote
Old 02-25-2003, 05:55 AM   #4
Cole Trickle's Avatar
Check this: http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Personally, I'm simply using 8 AA-NiMh in my KO EX-11. I think NiMh double-A can be found in 1800 mAh, which will last very long on one charge.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-25-2003, 07:02 AM   #5
CRASH's Avatar
Trader Rating: 26 (100%+)
Post Rechargable Cells
I use 1800 NIMH batteries and a plug from radio shack that plugs right into the jack on the M8s battery tray. Then charge it off my Millenium. Have had no problems.
CRASH is offline   Reply With Quote
Old 02-25-2003, 07:22 AM   #6
WVRACER's Avatar
so you got the connector from radio shack and split the wiress so you can hook it up to your novak charger.
what do you charge at with the novak
thanks
wvracer
Old 02-25-2003, 09:35 AM   #7
BBSpence's Avatar
Trader Rating: 45 (100%+)
GP makes a 2000mah AA now...
BBSpence is offline   Reply With Quote
Old 02-25-2003, 11:01 AM   #8
CRASH's Avatar
WVRACER
I charge at .6amps on NIMH setting. Absoultely no problems at all. Yes just split the wires put a plug of some sort on the end and connect it to your charger and your done.
Old 02-25-2003, 11:07 AM   #9
Turbo9000's Avatar
the M8 stylus pack at tower is like 60 bucks and 700mah...I think
Is there any modifications that have to be done when switching to rechargables?
Turbo9000 is offline   Reply With Quote
Old 02-25-2003, 11:08 AM   #10
WVRACER's Avatar
thanks crash.
i have been using that trickel charger i did't know that the tray would handel the quick charge. i could have used it a few times.
has anyone used the 2000 gp's in there radio? just wondering if it is to much or the way to go.
thanks
wvracer
Old 02-25-2003, 11:11 AM   #11
WVRACER's Avatar
hay turbo if you pull out your battery tray look on the bottom you will se a charging plug. just get you some rechargable batts and use that and save you alot of cash and more mah
thanks
wvracer
Old 02-25-2003, 12:28 PM   #12
I bough AA NiMH's from radio shack, used a Dremel to make a hole in the bottom of radio, so I don't have to pull the radio tray out. I used a tyco 9.6v NiMH charger (for their little cars) and soldered a plug onto the wires after removing the tamiya connectro.
So all I do is plug it right in through the hole in the bottom of the radio.
The charger is a radio shack, or tyco charger for 9.6v packs.
Pit Crew is offline   Reply With Quote
Old 02-25-2003, 01:23 PM   #13
Turbo9000's Avatar
cool... this will save me $$$ on those dry cells. the m8 even takes more batts than my old caliber
Old 02-25-2003, 01:35 PM   #14
rcdougie's Avatar
I purchased some 1800 AA nimh from walmart for about $20. Hitec/Airtronics charge jacks are the same for charging so I use the Lynx 3D charger to do the job.
rcdougie is offline   Reply With Quote
Old 02-25-2003, 02:00 PM   #15
Slightly off-topic, but here goes: It's a good idea to discharge those TX-batts from time to time to 0,9 volt pr. cell. I didnt do it for 1 a year, then I did, and it helped a lot on the capacity. (NiMh type)
M8 Rechargable Battery Flying Monkey Radio and Electronics 12 08-03-2008 09:06 AM
wtb m8 rechargable battery and charge will g R/C Items: Wanted to Buy 0 09-12-2007 11:36 AM
DX2 WITH RECHARGABLE BATTERY PACK AND RECIEVER rnichols R/C Items: For Sale/Trade 5 12-21-2006 08:02 PM
F/S: JR XS3 Pro w/rechargable Pack & Charger Mr T-Maxx R/C Items: For Sale/Trade 6 11-09-2005 03:27 PM
Airtronics M8 rechargable batt. pack. Reuben Johnson R/C Items: For Sale/Trade 2 03-11-2005 04:42 PM
