Bearing Oil
Old 12-01-2006, 08:46 PM
Centerline Racing's Avatar
Trader Rating: 47 (100%+)
Bearing Oil
What type of oil for bearings? All of the plastic dust covers are gone. How often do I need to re-clean and re-oil them?
Centerline Racing is offline
Old 12-01-2006, 08:59 PM
Mr. Shookie's Avatar
This is really good stuff...
http://www.teameamotorsports.com/cat...products_id=51
I clean my bearings after every race day.
Hope that helps,
-Shookie <><
Mr. Shookie is offline
Old 12-01-2006, 09:20 PM
Even the ones in the diff? That seems a little excessive and time consuming.
I could see cleaning the wheel bearings after every race, but all of them?
Old 12-02-2006, 09:45 AM
Not if the diffs are sealed. Those get done about every two full weeks of running, when I rebuild the diffs.
Hope that helps,
-Shookie <><
Old 12-02-2006, 10:14 AM
Ballsie's Avatar
Yokomo Friction Zero is second to none, but difficult to get a hold of.
Ballsie is offline
Old 12-02-2006, 10:17 AM
adamge's Avatar
Shook, what is a bearing cleaning procedure? Do you remove the seals, hit them with brake clean, then apply this oil?
-Adam
adamge is offline
Old 12-02-2006, 10:37 AM
-Adam
Lets just say I buy xacto blades in bulk.....
So yea seals than clean with motro spray, or the electic rattler. It all just depends on how I feel....
When I do the 8th scale it is the elctric rattler for sure...
-Shookie <><
Old 12-02-2006, 11:04 AM
Fervidsea's Avatar
Check the link in my sig... Wicked Fast has great Bearing Oil and Diff Lube.
Fervidsea is offline
