Old 11-27-2006, 01:41 PM   #1
Default Turning Radius with a spool
After changing to a spool , the turning radius will increase due to lack of diff action, is there a tweak, that can help offset that? I run my T2 007 EU on an asphalt track that has a pretty tight infield section. I had been running a front diff because of that. But after upgrading my rotor in my brushless motor I finally got brakes . Unfortuanately, once I apply brakes, the car almost always pulls to the right. This exact same thing happens on my friends T2 with similar setup. I installed the spool and the car now brakes straight and true, however I sacrificed turn radius .
so, anyway, there is the whole story. any suggestions are welcome.
thanks
Lon
Mugen MBX6E Tekno V4 Tekin RX8 Tekin 1700
Losi SCTE 4x4 , Tekin RX8, Tekin SCX4-5.5
Associated SC10 4X4, Tekin RX8, Tekin SCX4 -5.5
Kyosho Ultima SC-R, Tekin RS Pro, Tekin 10.5
Lon_L is offline   Reply With Quote
Old 11-27-2006, 02:11 PM   #2
sosidge's Avatar
You'll never get the slow speed turning circle back, all you can do is adjust the setup so the rear of the car slides a bit more in turns if you are carrying speed.
Old 11-27-2006, 04:22 PM   #3
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
i noticed while driving a spool, the corners need to be taken differently. you need to get off the throttle earlier to help weight transfer to get back the intial bite. you need to get back on throttle sooner to help pull the car through the corners. it also helps if the rear end is a little "looser" this helps the car rotate b/c the rear wants to come around and pivot on the front tires.
-Zac
Z.Hallett is offline   Reply With Quote
Old 11-27-2006, 04:53 PM   #4
Thanks for the replies guys. I will continue to try and adjust my driving style . The only other solution is go back to using the front diff, but then I have to turn the brakes way way down, or the car pulls under braking.
thanks again
Lon
Old 11-27-2006, 05:16 PM   #5
AngryAsian's Avatar
Pull right under braking? - Got tweak?!
Otherwise - you have to be fairly enthusiastic when you using a spool. I usually use a one-way and prefer a smoother flowing driving style. Lots of rolling on/off throttle and practically no brakes.
But when you drive a spool, it's much more on the throttle to rorate the car, jump on the brakes at the last moment and flick the steering in. Much more "Aggressive" style is required to get the car to rotate. But you'll also need to change your setup to let the rear rotate like the others have said..
But lastly - check that tweak!.. a diff equipped car should still have fairly decent brakes!
AngryAsian is offline   Reply With Quote
Old 11-27-2006, 11:44 PM   #6
My tip - Run less rear droop and more caster (front) - the Idea being getting the inside rear wheel off the ground or at least unloaded (just like you do in a go-kart). I believe an even smoother style of driving is needed with a spooled diff especially if it is setup to unload the inside rear tyre.
Joly Joe Junker is offline   Reply With Quote
Old 11-28-2006, 07:34 AM   #7
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
how about a slightly softer spring on front then back
when you enter the corner weight will go forward better also on power situ will be even better then before
trial & error i suppose
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Turning Radius bds Nitro Off-Road 7 06-23-2008 10:43 PM
Radius on fresh cut 1/8th scale tires. Loveless Nitro On-Road 1 12-27-2007 08:00 AM
difference on the rimes radius Rasmus TbEvo IV Electric On-Road 3 02-02-2006 02:06 PM
T3 turning radius differences L and R? oMONSTERo Electric Off-Road 5 05-05-2005 07:42 AM
tighter turning radius corvettecrazy Electric Off-Road 0 07-18-2003 09:58 AM
