Old 02-23-2003, 04:42 PM   #16
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Talking Should work
Originally posted by AssociatedRacer
Will the Ko work fine with my m8?
No problem
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-23-2003, 05:03 PM   #17
Talking Should work
No problem
-Dave
Old 02-23-2003, 09:34 PM   #18
Send a message via ICQ to Jason-Pro Send a message via AIM to Jason-Pro
i have a JR 8450 in my TC3. i love it, its got the speed and torque thats perfect for a sedan.
also i think JR has the best warranty service ever. I've talked guys sending them back with just stripped gears and they have sent them back with new set of gears in it plus a extra set !
i just like there service thats why i run all JR. R-1 radio is luv to !
Jason-Pro is offline   Reply With Quote
Old 02-25-2003, 10:23 AM   #19
Speed Demon's Avatar
how about the voltage??
ko 2023 is rated for 7.2V
ko 2143 is rated for 6V
which one is the best?? I am using M8 with the original rx...
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 02-25-2003, 10:44 AM   #20
for the 7.2v servo it uses a lead off the speed controller i think.
but youd want the 7.2V one for sure it most likely has better specs.
Old 02-25-2003, 12:17 PM   #21
I would have to say that the Ko 2143 is better for your app. -Dave
Old 02-25-2003, 12:29 PM   #22
Trader Rating: 24 (100%+)
Mike F,
The Multiplex mcv2 is a digital programmable.It does require a seperate programming unit. The price I quoted was correct. I bought mine for 69.99.
Evoracer is offline   Reply With Quote
Old 02-25-2003, 12:31 PM   #23
BTW...the programmer is 50.00$
Old 02-25-2003, 12:33 PM   #24
Cole Trickle's Avatar
The price is usually the same. The 2123 are 0,06 sec / 60 deg, and the 2143 are 0,08. The 2123 are probably a little stronger too. I got the 2123 myself - I honestly dont know if I can feel the difference, but I choosed the fastest, just to be sure.
7,2 volt servos, can be connected in two ways: either to the FET wire from the ESC or, directly to the battery. The last method is if the ESC aint got a FET wire. The only difference is that you need to solder a coil between the servo and the battery, if your ESC aint got the FET wire.
KO 7,2 volt servos comes with a little manual, that shows how to connect the servo with both methods.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-25-2003, 02:41 PM   #25
dw
You need a coil /choke even if you connect to the fet wire. Not installing one means you risk blowing up the servo. The fet wire from the speedo is just a connection to the positive battery terminal.
dw is offline   Reply With Quote
Old 02-25-2003, 03:12 PM   #26
It looks like a 6V servo is more to your liking
-Dave
Old 02-26-2003, 04:16 AM   #27
I think the choke coil is built in in the ESC - as far as I remember, the KO 7,2 volt servo manual dont mention that it's neded to solder in a choke coil between the ESC FET-wire and the servo. I'm not sure though.... If I remember it, I will check tonight.
WTB 1 high tourqe servo i high speed servo icantdrivetc5 R/C Items: Wanted to Buy 5 07-28-2008 06:08 PM
WTB: AIRTRONICS HIGH SPEED / HIGH TORQUE SERVO Rolex R/C Items: Wanted to Buy 0 03-05-2008 09:21 AM
Servo, high speed, high torque GSM Storm Australia Wanted to Buy 1 09-21-2007 01:38 AM
Hitec Digital Servo (high speed/high torque) 2-Bad Australia For Sale/Trade 5 07-01-2006 02:13 AM
WTB: Cheap High Speed/High Torque Servo. DOMOisCOOL R/C Items: Wanted to Buy 1 03-09-2004 12:41 AM
