Old 11-26-2006, 11:10 AM   #1
kuzo's Avatar
Send a message via MSN to kuzo
Default Transmitter lipos
I was looking for battery packs for my Spektrum and noticed this lipo pack. I assume this ends up at 12.6V after fully charged. Will a transmitter handle this extra voltage?
kuzo is offline   Reply With Quote
Old 11-26-2006, 11:40 AM   #2
AdrianM's Avatar
Yup, its no problem at all. Be sure you get the correct type of charger for your transmitter lipo pack. It must be LiPo compatable and be sure to use the charge settings in the packs instructions.
Adrian Martinez
Old 11-26-2006, 05:56 PM   #3
kuzo's Avatar
Adrian - Thanks for the quick reply the voltage difference was throwing me. Going to order soon. Charging shouldn't be a problem as I have both the Ice and Orion advanced avionics chargers. One of those will handle it. Plus I have the Orion balancer which should be beneficial. As with all lipos, I'll make sure to read the instructions carefully.
Old 12-06-2006, 07:01 PM   #4
kuzo's Avatar
So I ended up getting this lipo from RCMart: tx lipo
Got it in today and have a couple of questions for a lipo expert. I noticed that none of the tx packs have a balancing port. Is it not necessary at the low amp draw a transmitter has?
Second, the pack label does not specify a charge rate. The pack is 2500 mah with a 10C discharge rating. Is a 1C charge rate ok or should I go with less? Charging with an Ice with a temp probe set to cut at 90 degrees.
Old 12-06-2006, 09:50 PM   #5
kcrunchone's Avatar
When you use the ice charger it will auto set the charge value. Do not try and change the value that is set you will damage the pack and render the lipo into a state where it could possibly be damaged or worse cause damage.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 12-07-2006, 10:42 AM   #6
MrBlack's Avatar
many transmitter packs leave out the balancing port to save on cost. Since you will not be drawing in bursts like a pack to drive the vehicle haveing the cells come out of balance is less of a factor but over time since they tend to use cheap cells (10C) you may want to in the future go with a pack that has a balancing port of some kind. Most 3cell Lipo's if not all will be fine.
If it is 2500mAh charging at 2.5A should be OK I would always check wiuth the cell manufacturer to be sure.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 12-07-2006, 10:45 AM   #7
kuzo's Avatar
Sounds good then. Charging at less than 2500 mah will not harm it I assume? I can safely charge at 1500 mah with no ill effects?
max amp lipos Crazy Carl R/C Items: For Sale/Trade 3 12-01-2008 06:53 PM
new to lipos and need help PoLsKiE Electric Off-Road 12 09-05-2007 05:02 PM
Max amp lipos Khan48 Electric On-Road 0 02-19-2006 07:28 PM
fast charging transmitter pack whilst still in transmitter Xrayskid Electric On-Road 2 02-06-2006 04:16 PM
Transmitter for Transmitter Trade JDXray R/C Items: Wanted to Buy 4 10-28-2004 01:02 PM
