Old 11-26-2006, 07:16 AM   #1
MikeXray's Avatar
Trader Rating: 73 (100%+)
Default CP19t washer
Was there a washer ontop of the o-ring? I thought I saw one, but cannot find it now. The comm looks worse in the pic than it does in person, but I think it needs to be skimmed, it has 5 packs through it.
http://www.turbocarz.com/xray/CP19t.jpg
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-26-2006, 07:23 AM   #2
rtherbe's Avatar
Good question, my Orion revolution motor has two o-rings on either side of armerature, the washers are under the o-rings maybe yours is similar?
rtherbe is offline   Reply With Quote
Old 11-26-2006, 08:13 AM   #3
The 2 CP19 motors I have both got a washer (shim) above the rubber O ring.
Are u running the standard brushes to get the com like that after 5 runs, if so use the LONGLIFE INFINITY BRUSH they are well worth the extra. Last for ages and a lot less ware on the com.
Steve B is offline   Reply With Quote
Old 11-26-2006, 08:30 AM   #4
MikeXray's Avatar
Yes they were the standard set, I bought the infinity/silver spring combo on the recommendation of a few racers I wanted to check the comm before putting them in.
Old 11-26-2006, 08:37 AM   #5
Defo get the comm skimmed before fitting the infinity brushes, then to run them in run the motor at about 2 volts for 20 mins making sure the motor does not get hot during the run in.
washer behind the flywheel collet losiracer22 Nitro Off-Road 3 06-25-2008 04:34 PM
where to buy alu washer? genexis Singapore R/C Racers 6 11-27-2007 09:12 AM
funny washer thing holding my brake disc on? joe of loath Rookie Zone 2 08-04-2007 08:45 AM
XRAY - Wheel Mounting Screw/Washer Kit drx R/C Items: For Sale/Trade 6 05-13-2006 12:57 PM
How many washer should be used? adsl Onroad Nitro Engine Zone 2 09-26-2004 04:18 AM
