Old 02-21-2003, 10:51 PM   #1
Default Rollout
I'm trying to run foams and wondering where should i start with 10/11/12 double
fReShJiVe is offline   Reply With Quote
Old 02-22-2003, 11:26 PM   #2
Tom
Tom's Avatar
23mm-25mm
Tom is offline   Reply With Quote
Old 02-22-2003, 11:35 PM   #3
Neil Rabara's Avatar
Default Re: Rollout
What scale and type of car?
Neil Rabara is offline   Reply With Quote
Old 02-23-2003, 08:21 AM   #4
i just did some searching myself
Tom - 23/24/25 is close to what i found out for 12/11/10 rollout
RCInfinity - 1/10 th scale 4WD shaft driven electric car
i also found out that i need to gear according as the tires wears down...the question is if i start with both front and rear tires the same size and the front wear out 1mm and the rear wears out 0.5mm what do i need to do with the gearing or does it need more than a gearing change??with small tires in the front is this an overdrive??what are the effects of a car being overdriven?? ....by the way i dont have any access to a tire truer so truing it back to the same size equally is out of the question
Old 02-23-2003, 09:14 AM   #5
HarshGuy's Avatar
Coincidentally!!! I have a new version of the gear ratio calculator on my site. I added a "target rollout" chart, which will be helpfull in figuring out what pinion to go to on a car with foams in order to maintain the same target rollout you started with (i.e. as your tire diameter decrases).
http://www.arroyoc.com/index.cfm?fus...utilities.gear
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-23-2003, 11:00 AM   #6
HarshGuy - thank you very much ...that was really helpful...really appreciate that
Old 02-23-2003, 11:05 AM   #7
HarshGuy's Avatar
Rollout Help treemagnet Electric On-Road 1 09-11-2008 05:33 AM
rollout 3808larry Electric On-Road 3 12-12-2006 06:28 PM
rollout pinggoy Electric On-Road 3 05-07-2006 09:27 PM
rollout what is it ptjonesus Electric On-Road 5 01-13-2004 03:52 PM
Rollout what is it for? Alvin Electric On-Road 11 01-17-2002 09:36 PM
