KO Propo VFS-1 Competition II (C2) ESC >
Old 11-23-2006, 07:10 PM
akuhon's Avatar
Default KO Propo VFS-1 Competition II (C2) ESC
Hi all
I have some questions regarding this new ESC
1. Is it a really new ESC or just an improvement of default freq. setting from previous original VFS-1 ?
2. Compare to Hara Twister 2.1, Is it the same or better ?
3. Anyone has so far, share your experience please... I've seen it on RC Mag Japan ??
akuhon is offline
Old 11-23-2006, 09:57 PM
XrayFK's Avatar
It is a new and different esc. The Hara 2.1 is the same as the VFS-1 Pro Comp (original version)
XrayFK is offline
Old 11-23-2006, 11:47 PM
akuhon's Avatar
Thanks,
Is it Li-Po optimized ?
You know what are the differences between original VFS-1 ?
akuhon is offline
Old 11-24-2006, 01:02 AM
Stein Tumert's Avatar
Lightbulb Hara Twister 2.2
Originally Posted by akuhon
Hi all
[/IMG]
There is also a new Hara Twister 2.2 based on this new unit.
Read more here http://www.rctech.net/forum/showthread.php?t=134915
Stein Tumert is offline
Old 11-24-2006, 01:17 AM
Tek Nickal's Avatar
I have a question about these speed controls, do you need to purchase the setting adapter, or is it possible to use your computer to set it up? Through a data cable and software?
Tek Nickal is offline
bozla's Avatar
This links to ko propos page.
I think that when they say they've adjusted it to suit todays batteries, they mean 4 cells (as in the Japanese advert).
Its not a massive step, its just a development. If you already own the VFS-1, its probably not worth the money to upgrade. The only significant feature (having asked the guys at the track) is the adjustable drag brake feature. You get a lot of drag brake from the electric motors (especially those 23 turns)
bozla is offline
