Odd Novak GTX problem
My GTX has just developed a strange fault, wondered if any of you have had the same prob and therefore know of the fix.
1 when switched on the GTX works perfectly!
2 when it is switched off (but still connected to the cells) rather than doing nothing (as it has done previously) the motor now runs at about 10% power - which is a problem as I usually leave the cells connected to keep the cooling fans running.
any ideas?
any ideas?
The Evicerator
Definately an odd problem...
Out of curiosity have you been running a schottky diode on your motor?
Running without one over time can cause degredation of the transistors and could possibly lead to a problem state like what you have described.
The Evicerator
The GTX does have internal schottky diodes but due to the nature of the schottky it is MUCH more effective the closer it is to the motor... so we always recommend running another schottky right on the motor whenever possible.
The Evicerator
Yeah, I suppose you could connect it with a Dean's plug and still be ok
Yes I do run a motor mounted schotky as well......
