Old 02-20-2003, 08:36 PM   #1
Trader Rating: 37 (100%+)
Default Best carpet tires...
What in your opinion are the best carpet rubber tires?
Sorex
TakeOff
ect.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-20-2003, 08:40 PM   #2
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Foam is a rubber and they are the best hands down. But if you are talking about the none foam slip and slide tires then I would go with the sorex 28 they work very well for stock racing..
KINGZJ is offline   Reply With Quote
Old 02-20-2003, 08:41 PM   #3
KINGZJ's Avatar
I forgot to add that when I ran at Venture that is what I used with very good luck they also lasted pretty long.......
Old 02-20-2003, 08:43 PM   #4
mo
mo's Avatar
Yep, Sorex are the best!
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-20-2003, 09:15 PM   #5
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Sorex 28R's all around w/ red HPI inserts mounted on Yokomo Dish rims. That's what you should run. Ya Jesse i agree foam is the best, but you gotta be able to setup a car and drive it.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-20-2003, 10:09 PM   #6
Moderator
Speedo's Avatar
Ayy, Sorex are good. I think it really depends alot on the track and class you are running as to what comination to use.
Speedo is offline   Reply With Quote
Old 02-20-2003, 10:53 PM   #7
ShadowAu's Avatar
I've had some good results with Tamiya tires with the Tamiya molded inserts... but if you beleive the backroom whispers the 24mm Tamiya tires are made by Sorex anyway... but I ain't gonna be quoted on that
ShadowAu is offline   Reply With Quote
Old 02-21-2003, 03:06 AM   #8
Cole Trickle's Avatar
I'm using Schumacher white: Good grip (on our track) and pretty good lasting.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-21-2003, 06:57 AM   #9
dw
If the track allows them, Schumacher yellow minipins are by far the best tyre to use. Wear rates not too good though.
dw is offline   Reply With Quote
Old 02-21-2003, 07:49 AM   #10
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I have had very good results with Pit's. 24's 27's
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-21-2003, 08:54 AM   #11
KINGZJ's Avatar
mini pins on carpet! TO FUNNY
Old 02-21-2003, 09:40 AM   #12
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Nexus- depending on how much mechanical traction the carpet is producing, you will probably find that Sorex 24/20's are the best. You might be able to go up to 28/24s. I would use the Echo yellow insert or HPI red for stock racing. If you don't understand what 24/20 means- that's 24's in the front and 20's in the rear. Wouldn't you agree Mo?
BigDogRacing is offline   Reply With Quote
Old 02-21-2003, 09:44 AM   #13
LouisB's Avatar
I think mimipins and other tyres popular in the UK only work really well on Primafelt carpet, but you're right yellow mini-pins rule on some typed of carpet. Nearly all the US tracks use Ozite.
LouisB is offline   Reply With Quote
Old 02-21-2003, 10:04 AM   #14
CRASH's Avatar
Trader Rating: 26 (100%+)
We run 24/20s with HPI red inserts, 24/24s with HPI red inserts and 24/24s with HPI red inserts in the front with HPI yellow inserts in the rear. Those are the three combos that get used here the most.
CRASH is offline   Reply With Quote
Old 02-21-2003, 11:36 AM   #15
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Jason it sound's like what I run in the winter time here in Japan for Tire and Inserts Mostly 24/24 or 28/24 with the Echo inserts....but then again this is on Asphalt
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Tires for Carpet shaneriley2 Electric On-Road 2 05-08-2007 03:10 PM
rubber tires on carpet trilerian Electric On-Road 6 09-29-2006 04:36 AM
BSR carpet tires al spina R/C Items: For Sale/Trade 1 09-20-2006 08:12 PM
do you have differrent tires for carpet sm64000 Electric On-Road 8 08-03-2003 01:04 PM
