Cars Pushing off power >
Old 11-20-2006, 11:31 PM
TRFTIM's Avatar
Default Cars Pushing off power
My 414M2 is pushing (Understeering) whilst off power, and ideas on setup tips please.
TRFTIM is offline
Old 11-21-2006, 12:01 AM
Trader Rating: 31 (100%+)
Softer front springs, lower ride height in the front, more rear droop, softer sway bar up front, stiffer rear springs, heavier sway bar in the rear, higher rear ride height, more caster at front. There are a couple of things.
trilerian is offline
Old 11-21-2006, 08:25 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
are you using spool?one-way?diff? whats your current set-up?
Marcos.J is offline
Old 11-21-2006, 06:52 PM
trilerian: I think more rear drop won't help
ioxqq is offline
Old 11-21-2006, 07:26 PM
Jimmy Morris's Avatar
More rear droop will help. It will allow the car to transfer more weight to the front tires off power.
Jimmy Morris is offline
Old 11-21-2006, 07:27 PM
TeamPink91's Avatar
It will help due to an increase in the amount of weight transfer the car can put forward by jacking up the rear end of the car, but you will have to be careful because it can make the car push in mid corner.
TeamPink91 is offline
Old 11-21-2006, 07:31 PM
TeamPink91's Avatar
Dang Jim you beat me to it.
Old 11-21-2006, 07:51 PM
nf_ekt's Avatar
Trader Rating: 115 (100%+)
John why does it make for mid-corner push? So would you adjust front droop for this (mid-corner push)?
nf_ekt is offline
Old 11-21-2006, 08:14 PM
TeamPink91's Avatar
Jon, it will cause a mid-corner push due to the increased amount of suspension travel the additional droop(uptravel actually) creates, which will generate grip due to roll. I guess you could try and counteract it by putting in more front uptravel, but I really wouldn't start trying to cure an off-power push with droop anyway.
Old 11-21-2006, 08:20 PM
nf_ekt's Avatar
I guess your hinting at maybe adjusting rear toe first (decrease rear toe to make the rear break loose faster, less push in the front) or maybe a thinner front swaybar first.
nf_ekt is offline
Old 11-21-2006, 08:26 PM
kartermdb's Avatar
Trader Rating: 15 (100%+)
unfortunately it isnt as easy as it sounds, to fix your off power push, you are going to create or possibly fix other problems. to fix the problem correctly we need to know what your car is doing through the whole corner, what would you like it to do better in the middle of the corner and coming off on power?
kartermdb is offline
Old 11-21-2006, 10:00 PM
You're right, I was just giving some options he could do.
