Old 11-20-2006, 09:39 PM   #1
Default Rollout questions on these motors
I need to know what would be the rollout (or gear ratio) on these motors. I am running a T1FK'04 (1.77 internal ratio), 63mm tires on carpet. Track is pretty technical right now with one back str8 away about 50feet long.
Motors:
P2K2
Monster
CO27
Thanks, Chris.
falconcg is offline   Reply With Quote
Old 11-20-2006, 09:50 PM   #2
jkas10's Avatar
Trader Rating: 121 (100%+)
Here are some helpful references and tools for selecting gearing/rollout:
Roll out calculator
rollout article
Each motor may need a different pinion/spur combination. This should give you a starting point and adjust as needed. Your car internal gearing is listed in the article so that is helpful. (X-Ray low ratio (T1FK) == 1.77 )
Good luck!
jkas10 is offline   Reply With Quote
Old 11-20-2006, 09:57 PM   #3
63mm tires..... Ever take that thing off any sweet jumps?
j/k
MManson is offline   Reply With Quote
Old 11-20-2006, 09:59 PM   #4
edseb's Avatar
Maybe you should enter in the Truggy Nats.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 11-20-2006, 10:11 PM   #5
Rubber. (standard size no?)
Old 11-20-2006, 10:49 PM   #6
Trader Rating: 18 (100%+)
I would start around 26mm with the co27 (7.61 fdr with 63mm tires), should be about the same gearing with the p2k2, and a couple of teeth lower on the pinion for the monster
trilerian is offline   Reply With Quote
Old 11-21-2006, 07:38 AM   #7
Someone suggested to me around 29 for the P2K2 at the club. I guess that's why it burned up a bit. Monster was at 26 with no problem. 27 with monster, it lost some power at the end and was pretty hot.
I am waiting for my new CO27.
Questions on modding motors.....??? Mpowerz Nitro Off-Road 35 01-18-2008 04:46 PM
OS motors.Any answers for questions... Tron 101 Nitro Off-Road 7 09-24-2007 11:09 PM
Newbie Questions on Gear Ratio and Rollout SlamMan Electric On-Road 16 07-26-2006 09:20 AM
Electric Motors n00b questions Khan48 Rookie Zone 2 01-04-2006 04:46 PM
Questions on wheels and motors... warped5 Electric Off-Road 0 01-06-2003 01:35 PM
