M8 Airtonics Range problem...
hey i have problem with my range distance. i have m8 tx and cheap JR135r fm 3ch Rx. im not sure if it is the receiver or the radio. i know m8 airtronics pros use them. i cant go more than 100 feet and my car starts to glitch. close range i have no problem
all the wire are tucked in properly.
should i get spectrum to resolve this problem? i heard spectrum are 3000ft range.
Originally Posted by deadhero
cheap JR135r fm 3ch Rx. .
Originally Posted by BlueR1
found the problem. inside the m8 which holds the attenna is scratching one of the soldering which causes short distance range ...but i was surprise it wasnt glitching in short distance. pulled the metal peice that holds the antenna with the pliers. Tested it and went back to normal! thnx guys.
