Old 11-15-2006, 02:41 PM   #1
bigair78's Avatar
Default Foam tire maintenance after a race?
I just started racing carpet this winter. I am using foam tires. What is the correct maintenance between heats? I saw a lot of guys doing different things. What should I be doing in between races?
Josh
bigair78 is offline   Reply With Quote
Old 11-15-2006, 02:46 PM   #2
RaceAce701's Avatar
Trader Rating: 86 (99%+)
all i do is clean the tires using motor spray or oops
check for chuncks
check the tire size and keep track of tire wear
and glue the tire any place that the foam is pulling away from the rim to prevent chuncking
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 11-15-2006, 02:59 PM   #3
stiltskin's Avatar
Trader Rating: 102 (100%+)
check for chuncks
You could rotate the tires from side to side also. Helps get a little more life out of them. Make sure you are checking your ride height and droop between rounds too. I run my camber so that the tire wears flat, so use this time to make any adjustments for wear.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-15-2006, 03:02 PM   #4
Trader Rating: 16 (100%+)
What exactly is the stuff that ppl pouring (not sure that is the right term) onto the foams after run to clean the foam tires before adding traction compound...? I want the name of that stuff...it is a metal bottle with the folding yellow tab and you pour a line of liquid stuff onto the foams and clean it with towel....the size of that bottle is kinda like the bottle of a Paragon Ground Effect...thanks.
Old 11-15-2006, 03:05 PM   #5
stiltskin's Avatar
Might be lighter fluid. I just use motor spray. It does the trick.
Tony Rumple
Old 11-15-2006, 03:14 PM   #6
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Regular old can of motor spray. It's not needed between every run, just when you feel it's getting build-up. Also depends on the traction on the carpet.
Anthony.L is offline   Reply With Quote
Old 11-15-2006, 03:17 PM   #7
Motor spray sounds good.....now, is there a particular brand of motor spray that wildly accepted by racer here..? Orion? Reedy? AE? WD40?
Old 11-15-2006, 03:38 PM   #8
stiltskin's Avatar
I think the stuff I use is made by Dynamite. And to back up what Anthony L. said, you don't have to clean them between each round unless they are getting gummed up.
Tony Rumple
Old 11-15-2006, 04:02 PM   #9
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
WD-40 is a big NO-No. wd-40 has lubricates in it. this will make the tire greasy and slide around. motor spray or automotive brake cleaner work well.
-Zac
Z.Hallett is offline   Reply With Quote
Old 11-15-2006, 05:40 PM   #10
robk's Avatar
Trader Rating: 22 (100%+)
Rookie, you see us using Ronsonol lighter fluid. Motor spray works well also
1/10 Rubber tire preparation and maintenance nelarozi Electric On-Road 4 08-27-2008 02:09 PM
Tips on tire maintenance bryanleec Electric Off-Road 16 01-15-2008 07:40 PM
Rubber Tire Maintenance SpidarX Electric On-Road 13 12-23-2006 08:26 AM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
***NEW Race Trued Ellegi (GRP) Foam Tire Set of 4*** Dave Kurschner R/C Items: For Sale/Trade 5 12-18-2002 05:18 PM
