Old 11-19-2006, 08:27 AM   #16
Interesting.
What do you all think about the claims and science behind:
http://www.cmldistribution.co.uk/pro...subMenu=CR-ELC
High rev and high torque version??
8800 is offline   Reply With Quote
Old 11-19-2006, 09:19 PM   #17
Iceracer's Avatar
I'm interested in reading it, but that url doesn't work for me.
Iceracer is offline   Reply With Quote
Old 11-20-2006, 12:21 AM   #18
AngryAsian's Avatar
Mate... copy and paste the link manually. Otherwise, the address is not correct.
I assume it's just a size thing? "Torque" tuned would be analogous to having a larger capcitor. Takes longer to charge, but more capacity?
Apply the same principle to the diode? - Someone correct me if I'm wrong. I'm no electrical engineer..!!
AngryAsian is offline   Reply With Quote
Old 11-20-2006, 12:49 AM   #19
Tek Nickal's Avatar
I've noticed that many top drivers attach their diodes directly to the tabs of their motor, while I solder mine to the wires inline to the mother, does this have any lesser effect?
Tek Nickal is offline   Reply With Quote
Old 11-20-2006, 06:01 AM   #20
Arthur's Avatar
The closer the Schottky is mounted to the motor the better, I couldn't say how much better because I'm no EE.
The idea is that the Schottky offers a much easier path for the back emf than the brake fets in the speedo, so closer means lower resistance and better at attracting those little electrons away from the brake fet...
(If you mean you mount the Schottky inline as in in the positive or negative wire to the motor only then you have it wrong and the Schottky is doing nothing useful. I assume you mean you still have it across the positive and negative wires just a bit further from the motor.)
Arthur is offline   Reply With Quote
Old 11-20-2006, 08:42 AM   #21
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by "Spanky
A diode acts as a valve to
prevent electrons from flowing in one direction there by preventing any
electrical spikes from feeding back into the power feed.
That is why you will not see diodes included in reversable ESC's.
All the foward only ESC include diodes now. KO having the easiest to install...
Although I see alot of peeps using the Much More ones now.
Hope you can sleep well again..LOL
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
schottky diode? aus jd 2703 Electric On-Road 5 03-05-2007 08:45 PM
schottky diode? aus jd 2703 Australian Racing 9 02-05-2007 07:32 PM
much-more 55A schottki diode rampal Electric On-Road 2 02-05-2007 05:03 PM
Schottky Diode?? aus jd 2703 Electric On-Road 38 06-30-2006 03:14 AM
diode harddrive Electric On-Road 10 02-27-2006 10:40 PM
