Tamiya EVO IV MS
Tamiya EVO IV MS
Does anybody know if you can fit a normal ball diff in the front of an EVO IV MS?
If so, do I just order a standard rear ball diff and fit it in the front?
Cheers
Cheers
What's the part number to order the entire diff? I thought you have to order the diff in separate parts?
I dont know the part numbers but a ball diff will fit. You can also use Yokomo diff parts with Tamiya outdrives, again, I dont know the part numbers, your local hobby shop might.
HTH
HTH
I found the part numbers for each part of the ball diff, but it sounded like simon_allen knew how to order the entire diff an easier way. It's such a pain to order the diff in pieces.
