Old 11-13-2006, 02:50 PM   #1
Stevem9's Avatar
Default trf415 MRE Diff pulleys in MSX
does anyone have a how to on this.
Stevem9 is offline   Reply With Quote
Old 11-13-2006, 02:57 PM   #2
Tek Nickal's Avatar
There's a TRF 415 thread on this forum
Anyway, if your running diffs both front and rear, they are a direct replacement to the old pulleys. Also, you will need to set the belt tension as low as possible, as the belt as less slack due to the larger pulley. Because the pulleys are one tooth larger, the internal ratio of the car goes from 2.1875 to 2.25.
If you plan to run a oneway, and get the oneway pulley for the front, you will need to shave the material off the pulley to get it to fit.
For the spool it is also a direct replacement.
Tek Nickal is offline   Reply With Quote
Old 11-13-2006, 03:13 PM   #3
Stevem9's Avatar
so the rear would be a direct replacement? or would i have to shave the rear pulley also?
Old 11-13-2006, 03:56 PM   #4
stuey's Avatar
raed the previous quote again
stuey is offline   Reply With Quote
Old 11-13-2006, 05:56 PM   #5
Tek Nickal's Avatar
Yes the rear would be a direct replacement no modification required.
For the one-way I believe you can wait for the MRE version of the one-way, and you wouldn't have to shave material off the pulley.
Old 11-13-2006, 06:49 PM   #6
Stevem9's Avatar
i reread it ya that makes sense, sorry i have a head cold today...
thanks for the info i just need to find a rear diff pulley. im not sure if i want to keep the oneway up front or run a spool. i found a place that has the one way for the mre though
thanks again
SYD: HB Cyclone 18tooth Pulleys and Tamiya TRF415 Belts commander Australia Wanted to Buy 0 07-15-2008 05:57 AM
WTB: TRF415 FRONT ONE WAY DIFF HUCKMAN R/C Items: Wanted to Buy 4 03-05-2008 09:28 PM
TRF415 DIFF SLIPPING 16skyline Electric On-Road 1 10-27-2007 07:44 AM
TRF415 REAR DIFF 16skyline Electric On-Road 9 08-28-2007 10:29 AM
Metal diff pulleys TAO4R Electric On-Road 16 05-06-2003 11:54 PM
