Old 11-20-2006, 10:33 AM   #16
Top job, the finish you have is absolutely fantastic!
I know how bad it can be, I'm currently doing a Ferrari 333SP shell, the plug is coming along nicely, albeit slowly due to work commitments....
dancin stu is offline   Reply With Quote
Old 11-20-2006, 02:51 PM   #17
thanks stu. i've seen your thread for the 333sp. kind of a different approach to build the model/plug. theoretically your method should provide that extra bit of symmetry, i guess. and a legendary car too. i've been waiting for an update...and still do!
some pics tomorrow.
spyderdave is offline   Reply With Quote
Old 11-21-2006, 03:29 PM   #18
6. cut out the wheel housings and put together the parts of the body temporarily to find out if there are fundamental problems or something.
then i cut out the cockpit/monocoque area to get the dimensions for the monocoque and how to fit it into its spot. the core of the model for the monocoque consists of ABS-plastic, foam and a glassfibre-part similar to that one cut out before. the shape of the monocoque is still very rough and i am not happy with it yet. i also have to consider how to mount the front suspension, the diffuser and a possible crashbox. the pics explain it better...
The RS Spyder-pict4821.jpg   The RS Spyder-pict4832.jpg   The RS Spyder-pict4849.jpg   The RS Spyder-pict4855.jpg   The RS Spyder-pict4861.jpg
Old 01-08-2007, 02:01 PM   #19
7. sorry for not posting for so long. i somehow lost the motivation to work on the car for a while because i had to redo the mould for the monocoque completely. that was a little frustrating as it was nearly finished when i found out it was not right...whatever, now i built it again and it is finally ready for the next steps. i will try to keep the thread alive.
The RS Spyder-img_0262.jpg   The RS Spyder-img_0271_1.jpg   The RS Spyder-img_0245.jpg
Old 01-08-2007, 06:46 PM   #20
fraz's Avatar
Send a message via AIM to fraz
VERY NICE WORK!
I'd love to get that mold to the VacTool with some Lexan A few mods and it would be good to go. What would really be neat would be a 1/12 scale body!!
Again, super sweet job. Keep up the good work.
fraz is offline   Reply With Quote
Old 01-10-2007, 01:36 PM   #21
You have got a "VacTool"?....maybe we could put something together. I could produce another set of bodypanels or moulds, put them together and do the necessary modifications...no problem.
The size of the body should match standard touring car chassis or the F103GT quite well as it is designed for standard tamiya wheels. tell me a bit more about these modifications that need to be done.
Old 02-27-2007, 08:08 AM   #22
8. another update...finally.
i finished the core for the monocoque and managed to get a really smooth surface so the parts coming off the mould should have a nice quality.
i also finished both moulds for the monocoque. they fit together perfectly because i used some special joints you see in the pictures. this will help a lot while joining the two parts. theoretically, it also enables me to produce the monocoque as one part. but this seems difficult as the only opening could be the cockpit area...but maybe i will give it a try.
the first monocoque is currently in the making so i will post pictures of it tomorrow.
i already got some ideas to improve the monocoque and to integrate mounting points instead of drilling holes after pulling it off the mould. so i think i will have to modify the mould or even make a new one...lots of work ahead.
The RS Spyder-img_0413-01.jpg   The RS Spyder-img_0442-01.jpg   The RS Spyder-img_0446-01.jpg
Old 02-27-2007, 11:35 AM   #23
MrBlack's Avatar
Excellent!
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 03-11-2007, 04:50 AM   #24
9. the first monocoque...trial and error.
i pulled the first monocoque off the moulds and put it together. i think it does not look too bad but it is still far from perfect. i need to find a better way to bond both parts together. i also used too much gelcoat as you can see because the surface is not totally clear.
the most important thing is that now i decided to redesign the nose up to the cockpit. first i had planned to fit the dampers and the suspension inside the monocoque, just as it is done on the real spyder. but now i think it is better for service and easier to handle if the dampers are mounted on top of the monocoque. so i have to modify the moulds a little bit and lay up another one.
the positive thing is, that this monocoque is already extremely strong and stiff while being very lightweight. you can really feel it just by holding it. it is very impressive. it feels like it is made from ceramic or something...just much much lighter.
Old 06-26-2009, 03:27 PM   #25
Did you ever finish this off?
Old 06-27-2009, 12:18 AM   #26
espresso1967's Avatar
Trader Rating: 18 (100%+)
Don't think he will respond. Just checked his profile and he has not logged in a year.
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Spyder MR-1 with E-Trigger tmaxx2.5 Other Items: For Sale/Trade or Wanted to Buy 0 08-26-2008 05:11 PM
1/18 spyder RTR fs/ft Reck83 R/C Items: For Sale/Trade 3 07-30-2006 05:30 PM
1/18 spyder FS/FT Reck83 R/C Items: For Sale/Trade 4 07-20-2006 07:55 PM
FS: Spyder TL paintball gun iamjeff6 Other Items: For Sale/Trade or Wanted to Buy 9 03-25-2005 02:18 PM
Kyosho GP-10 Spyder FS Team_Akina_1 R/C Items: For Sale/Trade 0 02-08-2002 07:14 PM
