Comm lathe
Old 02-18-2003, 05:39 PM
Default Comm lathe
Wats teh difference between a stock and modified lathe ?
And can the team cobra 2000K lathe cut rebuildable stock motor ? ANd is it a good lathe to own ?
zoombie is offline
Old 02-18-2003, 08:49 PM
Trips's Avatar
Trader Rating: 16 (100%+)
A "stock" lathe is a lathe built for the old style non-rebuildable stock motors. Those motors needed to be cut with the armature still in the can.
The mod lathes will handle any mod or rebuildable stock motor. There's absolutley no reason to buy a stock lathe these days unless you have a stockpile of old style sealed stock motors to maintain.
I use the Cobra ProComm lathe for years on mods and rebuildable stocks. I've been completely happy with it.
T
Trips is offline
Old 02-18-2003, 09:00 PM
Super Moderator
Grizzbob's Avatar
Well to answer that it takes a little recent history lesson. Before rebuildable stock motors came along(& Trinity's Paradox was the first), you had to cut the comm while it was still in the motor can, & to do that you had to remove the brush hoods & use a stock comm lathe, which had a motor mount to hold the can still & a thin, narrow bit to get inside to the comm. Of course, now that we can remove the armature to cut the comm, we can do it with a mod lathe, so stock lathes are pretty much obsolete. And as has been said, the Cobra lathes are quite good, I've had my Cobra Pro Comm 2000 for about 6 or 7 years now & it still works great(especially after I installed a diamond bit, those things can cut for several YEARS without dulling if taken care of)....
Grizzbob is offline
Old 02-26-2003, 02:53 PM
Default So which is the best??/
On the market for a comm lathe. What s popular opinion on the best for the money.
hicheef is offline
Old 02-26-2003, 05:52 PM
Neil Rabara's Avatar
Any of the lathes out there will do the same job, just make sure that you get a diamond bit. The HUDY lathe has a lot of accessories, yet it is a bit pricey.
Neil Rabara is offline
Old 02-26-2003, 07:09 PM
On the topic of lathes, is the Power Base really worth the extra money for it?
AssociatedRacer is offline
Old 02-26-2003, 09:05 PM
Korey Harbke's Avatar
Yeah, make sure you get a diamond bit.
Korey Harbke is offline
Old 02-26-2003, 09:48 PM
popsracer's Avatar
Default Sushi Boy;
Since you brought it up.
Do you think a Diamond bit cut will make more Power than a good Carbide bit cut.
It seems alot of the experienced motor tuners are split on the Diamond/Carbide bit thing. Some say Diamond is best, some say Carbide works just as good and the price per cut ratio is about the same.
What are everyone elses experiences.......?
Thanks,
popsracer is offline
Old 02-27-2003, 12:31 AM
alfa's Avatar
i use carbide...no complaints here!
alfa is offline
Old 02-27-2003, 12:19 PM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I have both.. Carbide and Diamond for My Hudy.. and I have not noticed any differance ..but in price
-Dave
JDM_DOHC_SiR is offline
Old 02-27-2003, 12:22 PM
BBSpence's Avatar
Trader Rating: 53 (100%+)
The diamond bits last longer. My twister lathe with diamond bit is 11 years old and it still cuts great.
BBSpence is offline
Old 02-27-2003, 03:16 PM
Lightbulb Twister
Now thats a Name from the Past .. I think that I have 2 of there Stock motors laying around at home .
-Dave
Old 02-27-2003, 04:25 PM
The diamond bit seems to be a bit sharper. It STAYS sharp too. I had a carbide bit before and I didn;t liek it. It went dull fairly fast. The diamond bit is like hot knife through butter. It also gives a nicer finish. Just my opinion though
Old 02-27-2003, 05:56 PM
Good lathe discussion here too. Very informative. http://www.rccars.com/forums/showthr...=&threadid=374 AND here http://www.rctech.net/forum/showthre...0&pagenumber=4
elnitro is offline
Old 02-27-2003, 09:58 PM
twocan1's Avatar
I run an Eagle Racing Modfashion lathe with carbide bit. Have not had any problems but I would have liked to have had an end stop adjustment on it. I just use a piece of tape on the mount to tell me when to stop cutting. I think this is better than using the old eyeball.
Sam
twocan1 is offline
