Old 11-16-2006, 07:48 AM   #16
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Dont connect your battery to the radiator and you won't have a problem with it shorting out....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-16-2006, 02:27 PM   #17
bxpitbull's Avatar
Originally Posted by Section 8
I don't understand you problem (or the attitude)?
You were wondering what coolant they would use, so I told you. If you are worried about shorting out your electronics, you will use it. They will probably recommend it in the directions (they will probaby tell you to use it if they are touting a non-conductive coolant, particularly since its just about the cheapest liquid you can buy Its even available at the grocery store). Unless you rupture a line, pump or coolig head, water is in a closed system and never touches your electronics.
Its essentially a water cooled heat sink that bolts in between the mounting flange of your car and the motor. Its nothing more complicated than that.
Section 8, no attitude, but I was asking for a review and I perceived you as being a bit stand-off-ish "like , hey dummy don't you know". In any event, "Its essentially a water cooled heat sink that bolts in between the mounting flange of your car and the motor." makes perfect sense. That being said, seeing that no one has given a review, what about impact? How strong is it? Would it be able to withstand a hit or a nice "head on, apply directly to the forehead" crash?
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 11-16-2006, 02:29 PM   #18
bxpitbull's Avatar
Originally Posted by sosidge
The product has not been released, the only reviews you will find are from the developer which will not be entirely unbiased
We will all have to wait and see what this system REALLY does.
My point. To me, it appears that they tested it with one car on the track, monitoring temps, which is good. But, they say zip about durability in the event of a hit or crash.
Old 11-16-2006, 04:24 PM   #19
Send a message via ICQ to rcnewb2004
they say this system will withstand a fair amount of abuse
rcnewb2004 is offline   Reply With Quote
Old 12-11-2006, 08:42 AM   #20
bxpitbull's Avatar
Time to revive this thread. It appears that this cooling system is ready for purchase. It has a small write up in the latest Xtreme R/C mag. At $200 bucks a clip, cooling dont come cheap! Anyone willing to take the plunge?!?!?!??
Thermal cooling system (TCS) - is it worth it? Drift Demon Electric On-Road 4 11-19-2007 02:30 PM
Latest Products!!!! Thermal Cooling System ( TCS-BS ) yeahjamal Malaysian R/C Racers 2 09-18-2007 02:03 AM
The TCS Thermal Cooling System bxpitbull Electric On-Road 4 09-02-2007 08:04 AM
TCS - Thermal Cooling System 1st world review moumerico Electric On-Road 21 05-21-2007 11:34 AM
TCS THERMAL COOLING SYSTEM initialrays Electric On-Road 0 01-07-2007 11:57 PM
