Old 11-11-2006, 04:00 PM   #1
blackdog's Avatar
Default X-Ray T2 carpet set up
Hay All
So I bought a 2nd hand T2 X-Ray (sweet)
the car came with light purple springs up front and white springs in the rear.
Thats a start but as for having a real good dialed set up ???? I can't figure on any one .I you can help me out with this, I'm sure a book of set ups please do.
If you would like send to my email address [email protected]
Thanks in advance to everyone .
Matt
blackdog is offline   Reply With Quote
Old 11-11-2006, 04:57 PM   #2
Team Speedy's Avatar
Trader Rating: 42 (100%+)
What kind of surface are you running on? Carpet or pavement? There is a ton of setups if you go to http://forum.teamxray.com/xsheets.php . If your running on carpet, out on the Eastern Coast we run cyan (up front) magentas rear for carpet. We mow em to 58-59mm for a start and go from there. If you use the "baselink setup" its a good starting point. (Found here: http://forum.teamxray.com/xform/inde...ID=34&setup=t2 ) Should get you right on the money. Also if you follow the setup book in the kit (if you have it) gives you great detail about what each adjustment does and how it will affect the car. Great little guide might I add. I also believe there is a gearing chart (64 pitch 116 tooth I think) and a rollout chart for foam tires. (All the way from 60?mm-55?mm) (Only glanced at it, never study it.)
Hope that helps some.
RcAmerica | Xray | Hudy |
Team Speedy is offline   Reply With Quote
Old 11-11-2006, 07:31 PM   #3
blackdog's Avatar
Default hay
Team Speedy
It was carpet setups I was looking for
Matt
Old 11-11-2006, 09:05 PM   #4
If you want try this. This is what I ran today at a med bite indoor track. Car had a lot of steering, felt a little twitchy. Try it if you want. I would recommend the baselink setup as your first try though. This set up I am posting needs work, it's not perfect.
Edit-- The file I loaded for the pictures sucks. It's too small to show and I can not put anything larger onto the system. If you want the setup e-mail me. If not the baseline setup works fine!
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Nice carpet 190mm carpet body coastaltony R/C Items: For Sale/Trade 3 09-20-2007 05:50 AM
FS:RDX Carpet and rubber spec, T-Fource, Mi2EC Carpet spec rayhuang R/C Items: For Sale/Trade 28 12-01-2006 10:30 AM
Carpet Knife 3.1 "red"--just in time for carpet season!! Scottrik R/C Items: For Sale/Trade 10 09-27-2006 04:02 PM
BMI carpet T2 carpet ready dawgmeat R/C Items: For Sale/Trade 5 09-02-2006 08:17 AM
