Old 11-11-2006, 06:42 AM   #1
Default Yokomo Drift Car
Hi guys, I'm new to this forum, been into radio controlled boats for quite a while, I've decided to get into cars...
I bought a Yokomo Drift kit at the model shop few days ago, I've got the chassis built up, I've got some radio gear which will do for now (Futuba servo, tx and rx) and now I'm looking at motors and speed controllers......
Some advice would be appreciated as I'm pretty much a newbie on cars lol....
What sorta motor would you guys advise for this car? My budget is about 20 on the motor.....Speed controller I'm looking to spend about 40......I don't need anything to flash as I'm not racing the car, just for fun really.....
Sorry for essay Thanks Dan ...........
Dan5678 is offline   Reply With Quote
Old 11-12-2006, 04:40 AM   #2
Anyone??
Old 11-12-2006, 09:59 AM   #3
not sure what the conversion is, but if you go the yokomousa site and click around you can find motors and a speed control that they recommend.
usually its one of the cheaper high wind modified motors, as far as speedo don't think it really matters, lrp makes a couple of small ones that would be a good fit and have reverse. here in the states they are around $60.00 happy dirfting
Turtlemaster is offline   Reply With Quote
Old 11-14-2006, 05:49 AM   #4
AngryAsian's Avatar
Doesn't hugely matter if you're playing around...
Just go for what your LHS sells..
Some cheaper brands are known to go up in smoke so make sure they do a warrantee for you.
Lastly - the only thing you need to make sure of, is that the esc and motor are compatible. That is, and ESC is rated down to a certain number of turns. Run lower than that, and you risk frying the esc..
Oh.. BTW - make sure you loctite the steering kingpins in - or keep spares at hand. All brokomo's.. sorry.. yokomo's like to drop them out !!
Cheers!
AngryAsian is offline   Reply With Quote
Old 11-14-2006, 09:33 AM   #5
nagatahawk's Avatar
Default esc/ motor
the Novak XRS ESC is low cost and gives good low speed control.
use any 27 turn stock motor.
this combination will give you very good low to mid range control. the car will be very easy to drift with this combination.
cheers.
wn
nagatahawk is offline   Reply With Quote
Old 12-07-2006, 06:56 PM   #6
racenut's Avatar
Trader Rating: 15 (100%+)
Cheers!
Amen to that, been dropping a lot of that nasty pins!!!(also at my tamiya kits)
We used regular esc with reverse in drifting, mostly cheap futaba mc230, mc210, TEU-bk, and some novak and lrp with reverse.
We used motor with high turn. Mostly 540 silver can motor for its low maintenance and high torque which is best for drifting...
racenut is offline   Reply With Quote
*******Yokomo Drift red brakes And Drift tires***** Carpetracer92 R/C Items: For Sale/Trade 0 11-08-2007 07:16 PM
For Sale : Yokomo Drift Car with Electronics (Ready to drift) uniquexme R/C Items: For Sale/Trade 0 05-21-2006 10:15 PM
FS:Yokomo Drift SD CM Drift Kit blindwolf R/C Items: For Sale/Trade 0 06-13-2005 10:10 PM
wtb yokomo drift knightrider tc4 R/C Items: Wanted to Buy 4 02-24-2005 08:51 PM
Yokomo drift car macnkitty2002 Electric On-Road 2 10-18-2004 02:19 PM
