Old 11-10-2006, 04:16 PM   #1
Default Modified Motors Rebuilding
Hi fellows,
I am returning to RC after almost 15 years break - I have some modifieds in my stock and since I am only bashing around, I try to maximise the use of all the old stuff.
These modifieds were unfortunately, stripped apart and put back without much thought. In other words, the timing and +ve and -ve poles could be all screwed.
I know how to shim the motors, cut the comm and etc, etc but is absolutely clueless on how to tune the motors back to its original timing.
Can anyone who can help without me buying a dyno which will prove useless after the motors are back in order?
Thanks and appreciate lots.
mttbsg is offline   Reply With Quote
Old 11-10-2006, 04:18 PM   #2
Send a message via ICQ to Jan Larsen
Instead of using money on a dyno in an attempt to bring back old, obsolete motors, use the same money to buy yourself a brushless system. Brushed motors are a thing of the past now.
Jan Larsen is offline   Reply With Quote
Old 11-10-2006, 06:28 PM   #3
Pat Clark's Avatar
Zero timing is pretty simiple... If there is no mark on the can, align the hood mark directly in the middle of the two motor mounting screws.. If the motor spins in the correct directon your good to go, if it spin in reverse your 180 out.. Once you got it going in the right direction to advance the timing turn the endbell counter-clockwise to advance (looking at the endbell)..
Associated, Reedy, Tekin, Tq Wire, Protoform, Veytrec Design Lab
Pat Clark is offline   Reply With Quote
Old 11-10-2006, 09:20 PM   #4
turd ferguson's Avatar
Send a message via AIM to turd ferguson
http://www.deccosoftware.com/setTiming.htm
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline   Reply With Quote
Old 11-11-2006, 04:49 PM   #5
Default Thanks
Thanks a lot for such prompt suggestions. Brushless are cool but i cannot afford it now, especially if I am just bashing around. thanks, will try it later.
Old 11-11-2006, 05:42 PM   #6
AM03GT's Avatar
with 2 magnet motors zero timing is when the brush hoods are parallel with the magnets... there is usually at least one mark for zero...with the can stationary, counterclockwise turning of the hood increases timing...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 11-11-2006, 08:25 PM   #7
Send a message via Yahoo to jonswift
are you sure that brushless is the way to go? how come the winning cars are still using brushed motors?
jonswift is offline   Reply With Quote
Old 11-13-2006, 04:59 AM   #8
Default Take it easy
Hi Guys,
I think Brushless is good for lazy people like me. Not much maintenance. As for performance wise, I believe both have their pros n cons. then again, wat do I know? It is just that brushless is quite expensive 2 start with. so I am stuck to brushed motors then.
Modified Motors GSM Storm Australia For Sale/Trade 3 12-20-2006 12:05 AM
Modified Motors Rebuilding mttbsg Singapore R/C Racers 0 11-10-2006 04:21 PM
Rebuilding Motors.... Altrodesigns Rookie Zone 7 03-17-2004 06:06 PM
Rebuilding Motors SPC Racing Electric On-Road 7 03-05-2004 05:04 AM
Rebuilding stock motors Simon K Electric On-Road 12 03-20-2002 09:39 PM
