Old 11-09-2006, 12:10 AM   #1
agp
Default Can turbo 35BL charger batt higher than 3300mah?
could not find the specs anywhere. can this charger charge batt that is higher MAH like IB4200?
agp is offline   Reply With Quote
Old 11-09-2006, 12:18 AM   #2
STLNLST's Avatar
Trader Rating: 21 (100%+)
Yes it can. This charger was ahead of it's time many years ago. Everthing that has come out has been charging great with no problems. Lipo is the only down fall at this point.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-09-2006, 05:07 PM   #3
Thistle's Avatar
Send a message via MSN to Thistle
I use a Turbo35BL to charge my batteries, and yes, it can charge the larger mah. Depending on the software version though, it may shut off early. When I charge my 3800's, my charger shuts off after 2400 seconds. (This is at 6 amps). It just means that I have to re-peak.
Xray | Ofna | KO Propo | Tekin | Clockwork Racing Engines
Thistle is offline   Reply With Quote
Old 11-09-2006, 05:29 PM   #4
dsrbltoys's Avatar
I had the some problems cycling when I had mine. I was told to use the 7cell mode, but change the cutoff back to 5.4 volts. The lockout was not long enough, and the volts were still too high to start the discharge portion. I never had any troubles with the charge part though. Good luck.
dsrbltoys is offline   Reply With Quote
Old 11-09-2006, 05:36 PM   #5
Joel Lagace's Avatar
This was rectified with a CMOS(??) chip upgrade... what ever it was i called them and they sent me the new chip took me 30seconds to swap out and the thing was updated. No more need to use 7cell mode.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
[WTB] CE Turbo 35BL or Stealth Charger squarehead R/C Items: Wanted to Buy 3 08-12-2005 03:56 AM
need new stock motor and 3300mah batt. Sage11 Electric On-Road 10 07-20-2004 06:56 PM
Turbo 35BL charger w/ free batt Northerner R/C Items: For Sale/Trade 3 01-19-2003 09:29 PM
Turbo 35bl Charger moceanrc R/C Items: For Sale/Trade 0 07-16-2002 09:16 PM
Turbo 35BL, Protrak or Schulze Charger xray Electric On-Road 120 01-06-2002 05:23 PM
