Old 11-08-2006, 10:26 PM   #1
Default Rev 4.X
Speedmerchant Rev 4 rear link suspension with the CRC Gen-x rear pod? I was thinking this over at the track today and realized what an awesome/weird idea it was. I love the adjustibility of the speedmerchant rear end but I hate the four-bolt pod plates. I know some custom cad and machine work would be in order, but think of the possibilities!
Discuss and flame, but please no advertising (aka "omg just buy a CRC genx they are teh bomb")
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 11-09-2006, 03:36 PM   #2
okay, how about a question.
If I were to have a company (eg BMI) machine a new main chassis, rear lower deck, rear upper deck, and "x" brace that uses the speedmerchant rev4 style rear suspension and the crc x-brace pod plates, would there be a market for it?
www.freerice.com
Old 11-09-2006, 03:50 PM   #3
burgboyz's Avatar
Trader Rating: 70 (100%+)
Maybe for bmi to use it as a link 1/12.
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 11-09-2006, 04:53 PM   #4
true, but don't they have their own rear pod plates?
www.freerice.com
Old 11-09-2006, 05:44 PM   #5
protc3's Avatar
not to worry,we are working on a new 1/12th car right now.it will be link style with a twist. keep your eyes open.it will be in testing within 2 weeks.if all goes to plan,it will raise the bar on 1/12th cars
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-09-2006, 05:48 PM   #6
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
it looks awesome in the computer!! Cant wait to see it run!!
all you guys are going to love it!
Old 11-09-2006, 06:26 PM   #7
will it have easy motor access with a fully adjustable rear suspension? and how about an ETA?
www.freerice.com
Old 11-09-2006, 06:29 PM   #8
protc3's Avatar
very soon.if all goes well it will be available to the public by the snowbirds
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-09-2006, 06:58 PM   #9
stormperson's Avatar
Send a message via AIM to stormperson
With the 4.5 rear pod you can very easily slide the motor out from the bottom, there is no need to remove the top plate. There is no way to make it easier.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 11-09-2006, 07:05 PM   #10
protc3's Avatar
i think they are talking about removing the motor from the top of the pod like the gen x
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-09-2006, 07:36 PM   #11
correct, untill you have to solder wires to said motor
www.freerice.com
Old 11-09-2006, 09:32 PM   #12
odpurple's Avatar
To get what you want here all you need to do is replace the one piece CRC links with adjustable ones like the SM car has. This was a common modification to make on Carpet Knives, I don't know if there are any obstacles to doing it on the new car, but I bet it would be possible.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 11-09-2006, 09:43 PM   #13
yes and no. The other difference that I love about the SM car is how far out the tweak springs are and how the tweak plate is mounted. True, I could drill and tap holes to put the spring holders directly above the rear link mounts, but where is the fun in that
www.freerice.com
Old 11-09-2006, 10:57 PM   #14
smojoe....................dump that rev4.5 and get a crc gen x. You won't have to worry if you can get parts.
gotyournumber is offline   Reply With Quote
Old 11-10-2006, 12:37 AM   #15
odpurple's Avatar
You're making an issue where there isn't one. Both are link cars, where the side springs are is a minor detail. If your problem is just soldering the motor wires on, try attaching them on the bottom lugs.
