Xray T1 FK'04
Old 11-04-2006, 11:46 PM
surrealmaterial's Avatar
Default Xray T1 FK'04
Hey guys,
a few questions to ask about an Xray T1 FK04.
-can u put a heatsink on it?
-does it matter if the belt is touching the motor?
-is it possible to have a 6 side by side pack and still have good weight distribution?
thanks
surrealmaterial is offline
Old 11-05-2006, 12:15 AM
Impulse_racer's Avatar
Originally Posted by surrealmaterial
Hey guys,
thanks
Not easily because of where the motor is. I Shoo Gooed a small Novak fan to the chassis so that it blew on the endbell of the motor to keep it cool. I think Cool Cans may have have a fan mount for this car.
No.
Not unless you are running oval. Because the motor is centralized there is nothing to help the electronics offset the weight of the batteries.
Impulse_racer is offline
Old 11-05-2006, 12:38 AM
you know were i can get a cool cans cooler from
Old 11-05-2006, 12:59 AM
here is a pic of my fk04 with a heatsink.
think about keeping this car for when modified becomes 4 cell slap some t2 arms and cvd's on it and it should be a revived car
the heatsink is a el cheapo brand which i polished up packaged sometimes as "lazer" or "eagle racing" its a 6 fin heatsink which i cut down to 4 to fit ont he car. i held it in position with a long screw that goes through the other side of the baulkhead which has a hole in it and secured the screw with a nut.
TomB is offline
Old 11-05-2006, 01:01 AM
u know were i can get one the same?
Old 11-05-2006, 01:22 AM
www.coolcanfan.com
And the heatsink that TomB recommended can be found at Integy.com under "Motor Heatsink & Motor Parts".
Old 11-05-2006, 11:12 PM
ok thanks
Old 11-07-2006, 11:44 PM
can u fit sometype of fan to the FK'04?
Old 11-08-2006, 12:37 PM
Mr. MR4's Avatar
Yes you can fit one on the left rear bulkhead so that it blows air on the endbell.
Mr. MR4 is offline
Old 12-06-2006, 10:31 AM
xrayroooahhhh's Avatar
Default belt rub?
TomB.....in your picture it looks like your running a 48pitch spur. Does this help with the belt rub on the motor?......I found a 48 pitch 96 tooth spur....and it has a larger diameter than the 64 pitch that everyone runs up here....I haven't picked it up yet but this may help?
xrayroooahhhh is offline
Old 12-06-2006, 11:38 AM
Victor Vector's Avatar
I've got 6 cells on the right side of the chassis and by the time I've added 1 1/2 oz ballast to get to legal min, then there's no significant weight bias. Certainly no more than when the car's set up 3x3 style.
I did have to modify the servo cos I have all elex on the left. It took shortening the arm to the pushrod from the servo. This makes the steering a little more exitable, but still within the thresthold on sanity.
This ol' car is still wikkid fast, but mostly fun playing block to the T2s and 007z.
Victor Vector
Victor Vector is offline
Old 12-06-2006, 01:07 PM
if there a handling problem with 6 on one side? and were about did you put the weight
Old 12-06-2006, 01:50 PM
Default 6 on 1 side?
Victor....do you have pics of how you set your car up? Did you have a solution to the belt rub on the motor? Any help would be great!!
Old 12-06-2006, 03:12 PM
c-lyon's Avatar
Roy, in most cases the belt only touches the motor when at rest, not while moving. You can check the motor to see if it leaves a mark.
The 96/48 spur is about a 128 in 64 pitch. If you were using116/29 then 96/24 would be about the same gearing wise.
If you want to use a fan I can show you on Friday. It reduces motor temperature between 20 to 30 * F.
Colin
c-lyon is offline
Old 12-07-2006, 08:48 AM
Big Spur, Big Pinion...... no, Bigger Pinion; what ever it takes to get the motor as low as possible is my starting point.
I'll post some snaps to night.
VV
