Old 04-10-2009, 10:54 AM   #1411
Stuart Pid's Avatar
What revised chassis?
Perhaps you are thinking about the J spec car (used in Japan for running on asphalt)? It has a different rear pod plate and chassis (and can use longer side links) You can only purchase it from Japan.
The current chassis is single cell lipo friendly.
Suppose the Hokey-Pokey is what it's all about?
Stuart Pid is offline   Reply With Quote
Old 05-06-2009, 09:33 AM   #1412
espresso1967's Avatar
Trader Rating: 18 (100%+)
Considering picking up this kit to give it's big brother someone to play with. Any recommendations for asphalt as that is what I mainly run. Big track outside smooth sometimes dusted and sprayed with DHT. Sometimes dusty track if no racing. Other track is indoor asphalt sprayed with soda pop I believe. Just looking for ideas and wondering how different I should set it up from the Gen X 10.
Thanks in advance
P.S. lipo prefered any recommendations or should I go with nimh to put some weight on the kit? Also electronics recommendations as I use novak gtb on my Gen X 10 but know that is to tall for 1/12.
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 05-06-2009, 09:09 PM   #1413
Trips's Avatar
Trader Rating: 16 (100%+)
At 360 Speedway, guys mostly ran the GTB 4cell, or the Tekin RS. THe GTB worked with no rx pack or booster, the Tekin needed the booster or rx pack.
I had the Tekin in mine, with TQ booster and a SPektrum DX3R radio.l
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-07-2009, 05:42 AM   #1414
I ran my HB Cyclone12 with the GTB, just removed the fan. NP with either stock or mod. motors on 4 cells.
If you don't trust it, just try it and watch the temperature.
vassago is offline   Reply With Quote
Old 05-07-2009, 09:23 AM   #1415
ghiro's Avatar
Send a message via Skype™ to ghiro
Intresting! Do yuo have a link or futher info's for that ?
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 05-07-2009, 04:14 PM   #1416
Three's Avatar
Prototype photos:
http://www.redrc.net/2007/08/crc-generation-x-jspec/
http://www.teamcrc/modules.php?name=...article&sid=85
Part numbers:
3305 J-Spec Conversion - Gen-X
3355 J-Spec Chassis - Gen X
3366 J-Spec Bottom Plate - Gen X
3365 J-Spec Rear Top Plate - Gen-X
Parts cost about $100USD with shipping
Email to purchase: Kimihiko Yano ( http://www.kimihiko-yano.net/ )
Electric good..........
Three is offline   Reply With Quote
Old 05-08-2009, 09:00 AM   #1417
ghiro's Avatar
Thank's Three,how you a coupple of (virtual) beers
Old 05-09-2009, 08:17 AM   #1418
Trader Rating: 96 (100%+)
Did a search and ended up getting even more confused.
What parts / kit are needed for the latest brushless pod conversion?
I've got the old style brushed pod.
Any info is much appreciated.
K.Copeland is offline   Reply With Quote
Old 05-09-2009, 05:37 PM   #1419
wingracer's Avatar
Trader Rating: 24 (100%+)
This should explain it.
http://ashfordhobby.com/detail.aspx?ID=6674
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-09-2009, 08:50 PM   #1420
Yeah, read it.......5 times.
There is the " kit includes " part, then "you will need " section, and then " nice to have" section.
Having to piece together a conversion on a car I know absolutely nothing about is quite the headache.
Old 05-11-2009, 02:24 PM   #1421
johnnywhopper's Avatar
which rear pod do you have now? does the rear top plate go across the front of the motor to the left pod plate? or does it stop in the middle of the motor and mount to a standoff post connected to the center pivot?
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 05-11-2009, 03:07 PM   #1422
It's the brushed motor pod.
Old 05-11-2009, 03:11 PM   #1423
wingracer's Avatar
There are two brushed pods. Are your left and right pod plates the same or are they different?
Team Shepherd USA
Old 05-11-2009, 06:49 PM   #1424
Both aluminum pod plates are the same, there is no aluminum standoff.
Old 05-11-2009, 07:24 PM   #1425
You need to get crc3339 and crc3349. Between these to you will get everything you need for the conversion. Ashford Hobby is a good place to buy from if your local Hobby Shop can't get it.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
