Old 01-05-2008, 04:40 PM   #1261
So should you use track width more for traction correction, or for turning problems?
IMTK422 is offline   Reply With Quote
Old 01-05-2008, 04:40 PM   #1262
Maybell's Avatar
Originally Posted by IMTK422 View Post
WOW!!!!! Talk about fast service thanks.
no prob!
glad you are liking the car....its awesome!!
personally, I dont mess with it much....I use only CRC tires, so I set the track as the kit says, and adjust other things to dial it in...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-05-2008, 04:44 PM   #1263
Car Breaker's Avatar
I happened to have these laying around (genX chassis + rear End) if anyone interested, I will do 55 USD shipped, they are in good shape. sorry for post it here.
CRC's New Generation-X.... Your Thoughts?-p1010869.jpg   CRC's New Generation-X.... Your Thoughts?-p1010870.jpg
Car Breaker is offline   Reply With Quote
Old 01-05-2008, 05:56 PM   #1264
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Does anybody have a pic of the pro front end and brace I need to see a pic thanks
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-05-2008, 07:40 PM   #1265
bsmooth's Avatar
Trader Rating: 17 (100%+)
Guys, I have a question about diffs.
I went to a Kimbrough 88t spur and replaced the 8 steel balls with 12 ceramic balls.
I'm running a 27t motor, and I had to really tighten down the diff nut in order to keep the diff from spinning (sounded like the clutch on a 100cc yamaha kart!!).
Is there a better "system" to use? I heard a few Guys talk about different diff rings (Niftech) and such to try.
Thanks in advance for any help.
-Steve
Other than that the car was pretty dialed.
bsmooth is offline   Reply With Quote
Old 01-05-2008, 07:58 PM   #1266
Maybell's Avatar
-Steve
so far what has worked best for me is 12 carbide diff balls in a Kimb. spur with the red label Associated diff lube...but I am about to test some new Axiom ceramics at a big local race Jan 18-20....stay tuned, I will let you know how it goes...
I dont believe what diff rings you use matters much...
Old 01-05-2008, 08:37 PM   #1267
Gael L's Avatar
http://www.teamcrc.com/crc/images/st...ongarm-800.jpg
http://www.teamcrc.com/crc/images/st...ck_1-2cars.jpg
Gael L is offline   Reply With Quote
Old 01-05-2008, 09:35 PM   #1268
odpurple's Avatar
-Steve
Steve,
The set up you have should work fine. Next time you are at the track let me look at the car and we can get your diff dialed in
BTW, Niftech diff rings are the best but you have to use them with a Niftech diff as they are pinned.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 01-06-2008, 01:32 AM   #1269
wallyedmonds's Avatar
crc light diff rings are best with ceramic balls and red ae lube.
sand the rings and use a slapmaster and its butter.
wallyedmonds is offline   Reply With Quote
Old 01-06-2008, 08:23 PM   #1270
bsmooth's Avatar
Originally Posted by odpurple View Post
Steve,
Thanks.
If I get there early enough, I'll come find you.
-Steve
Old 01-06-2008, 08:24 PM   #1271
bsmooth's Avatar
I'm using the light rings, ceramic balls, and red a.e. lube. What is a slapmaster?
Thanks,
Steve
Old 01-06-2008, 08:27 PM   #1272
Thanks,
Steve
thrust bearing.
Old 01-06-2008, 10:10 PM   #1273
bsmooth's Avatar
thrust bearing.
Got it!
Old 01-07-2008, 04:19 PM   #1274
bsmooth's Avatar
I've been running the stock class lately, and have a pretty good setup. I haven't changed it too much from the kit setup except for: red center spring, 0 deg toe, 3.5mm ride, 1.5 camber. Jaco Prisms Lilac front, yellow rear.
I want to run the 19t-13.5 class, and I want to understand what the car needs to be doing to handle the increase in power. I know I could go on CRC's website and copy some setups, but what i'm looking for is someone to help me understand what the different setup will do.
I know that in stock, the car needs to be more "free", or not as bound up (robbing power). So, in 19t we need to tighten up the car, or add more grip?
If this is so, what adjustments do we go to first?
Most importantyl, how should the car feel?
Sorry for the drawn out question, and I do appreciate the help everyones given so far.
-Steve
Old 01-07-2008, 09:47 PM   #1275
-Steve
1 its 19t or 10.5
you may want to try 2x pink front and pink rear tires,the rest is fell and driving style,you got to play with setup but i think others here can explain better.
but if you go with BL you wont need to worry about your motor changing,its got good power all the time and you can work on your car more.
drive, get smooth and practice.and play with your radio settings for your steering,to much steering can rob the car corner speed.
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
