Old 12-26-2007, 09:53 AM   #1246
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Originally Posted by dgullickson View Post
I will add 1/8 to my next order, give it a couple weeks with the Holidays shipping takes longer.
Quante - Mine are different than any others and the cage on mine holds up as it is a solid piece with the balls precisionely (sp?) set in - your "opinion" is appreciated but cannot be backed up since you have not tried ours.
Added 1/8 to my order and they will be here next week. I am adding to the site now.
dgullickson is offline   Reply With Quote
Old 01-02-2008, 06:52 PM   #1247
1/8 Ceramic Balls are now in stock and on the site, For Sale even...
Sean - PM me your address and I will send you some and some other things to Test
Old 01-02-2008, 07:08 PM   #1248
Maybell's Avatar
cool, Im on it!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-03-2008, 11:40 AM   #1249
How many washers are you guys running on the front and rear tires for spacing on CRC tires. Also do you guys space them any different if you run Jaco Prizms. Thanks
IMTK422 is offline   Reply With Quote
Old 01-03-2008, 12:24 PM   #1250
smyka's Avatar
Send a message via AIM to smyka
i think some of the crc guys run three i personally run one with jaco prizms
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 01-03-2008, 12:32 PM   #1251
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
With high rollers I have .06" of shims on the inside of the front tires with high traction. Rear is stock, whatever came in the kit.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 01-03-2008, 03:28 PM   #1252
I run 3 in the front with CRCs and none with the prizms.
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 01-03-2008, 10:16 PM   #1253
wallyedmonds's Avatar
i run
the front is 167mm the rear 171mm the max rule for rear is 172
wallyedmonds is offline   Reply With Quote
Old 01-05-2008, 03:26 AM   #1254
Exclamation Re...GTB4CELL Install
hey guys I just opened my Novak GTB-4. Does anyone have photos of an install in the GenX. Is there a preferred location or directional orientation of ESC. I'm using an Airtronis 94145 servo offset to the left with kit red mounts. Any help would appreciated. Thanks!!!!
TJ
THEBIGBULL is offline   Reply With Quote
Old 01-05-2008, 07:15 AM   #1255
On the rear with prizms, I use 5 shims on the left and 6 shims on the spur side (172mm). Front I run 166 to 168mm. CRC rear tires 2 shims left and 3 shims on the spur side.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 01-05-2008, 07:57 AM   #1256
Mr. Bubby's Avatar
TJ
It's gonna be a tight fit but it will work. I put mine to the right of the servo, almost snug up against the fiberglass battery bar brace. It will probably hang over the edge of the chassis a smidge. The wire side of the speedo is on the outside of the chassis. The damn cap is the biggest problem. You could probably mount it in front of the speedo, but ya really can't see the set-up lights too well when ya do it this way. So I've just got mine loose and just snug it up in the driver's shell when I put the body on. Just make sure that none of the ten million wires impede the smoothness of the suspension. Hope this helps. Have fun racin'....It's a hell of a car
Mr. Bubby is offline   Reply With Quote
Old 01-05-2008, 03:13 PM   #1257
TJ
I mounted mine the same way with the cap in front of the speedo wedged betwen the right front arm and the servo. I would post pics but have no camera with me. It looks like there is a lot going on on the chassis but it works out okay.
rcdepot.us
nxgraphics.ca
Old 01-05-2008, 04:35 PM   #1258
As far as rear track width goes. What does widening the rear track width do? Sorry for all of the questions. I am new to 12th scale, but am loving this Gen-X car.
Old 01-05-2008, 04:37 PM   #1259
Maybell's Avatar
the wider the rear end is, the more stable the car is, and the less steering the car will have...
Old 01-05-2008, 04:38 PM   #1260
WOW!!!!! Talk about fast service thanks.
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
