Old 12-01-2007, 10:06 AM   #1186
Maybell's Avatar
Originally Posted by Carpetracer92 View Post
hey guys i want to make my servo flat with out using shoo glue. so does crc sell anytihng that makes it flat cause the ones it comes with makes it look like a angle.
all I can say is "dont do it"!!!!!
if you gotta try it.....take a look at the Paul L. car in the Cleveland report on the CRC site...but the front end is not really designed for a flat servo and either is the chassis...looks like Paul placed the servo pretty far foreward to get the correct bump-steer...good luck!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 12-03-2007, 10:14 AM   #1187
Gael L's Avatar
Originally Posted by chicky03 View Post
Here is my setup from the Indoor champs for 19T. Aaron and I ran the same thing. If you have any questions let me know.
Ran this setup this weekend and it is indeed a great setup. It really smoothed out my car. Everything else I tried this year made the car twitchy but this was the ticket.
Laterz
Gael
Gael L is offline   Reply With Quote
Old 12-03-2007, 11:39 AM   #1188
Send a message via AIM to Deznuts05
Default CRC center Spring Kit
I just bought the CRC Center Spring kit and I noticed that they are a boat load heavier than the AE Springs... Can someone tell me in the which spring is close to the gold AE spring? thanks
Deznuts05 is offline   Reply With Quote
Old 12-03-2007, 12:29 PM   #1189
johnnywhopper's Avatar
Yea the side walls.
The center spring colors softest to hardest:
Black
Green
Silver
blue
gold
red
copper
same as associated up to copper. the .050 silver spring is next followed by the .055 silver spring which is the stiffest.
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 12-03-2007, 01:07 PM   #1190
Thanks johnnywhopper,
My bag-o-springs came with red, copper, silver and a gold-ish silver... I guess I bought the wrong spring kit. Does CRC have the softer spring kit or do they recommend to just get the AE springs?
thanks all
Rudy
Old 12-03-2007, 03:48 PM   #1191
Johnny Wishbone's Avatar
Default Center spring kit
D05, whats the part number of the spring kit you bought. Can probably tell you what you got from that.
Old 12-03-2007, 09:50 PM   #1192
thanks johnny,
I ordered the CRC 1344
Old 12-04-2007, 07:50 AM   #1193
Trader Rating: 68 (100%+)
Send a message via AIM to joey
for anyone running prisms, exactly how many shims per side do you have on the axle in the rear..
=Joe Wright=
joey is offline   Reply With Quote
Old 12-04-2007, 08:38 AM   #1194
Default Center springs
CRC 1344 spring kit consists of springs 1340/red, 1341/copper, 1342/silver(.050), 1343/silver(.055), the optional spring is 1339/blue. The other ones must come from other models. You could check the CRC web site and poke around a little for other spring listings, I'm pretty sure the center shock is the same on each model, unfortunately the springs aren't listed by thickness or as a group. 1348/gold is the only other one I could find listed.
Old 12-04-2007, 10:08 AM   #1195
The car kit comes with gold and the 1344 spring set comes with all the stiffer (than gold) springs. Softer than gold (blue and down) are really only meant for t-bar cars. CRC recommends not using softer than gold.
jw
Old 12-04-2007, 12:26 PM   #1196
good looking out
I guess its off to the AE world for spring shopping
Old 12-04-2007, 01:34 PM   #1197
Maybell's Avatar
just make the rear ROAR max width...I think it is 6.75"
should be a good starting point...
Old 12-13-2007, 08:45 AM   #1198
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default tires
Are any of you running the Jaco Prisim tires? If so, how do they compare to the Pro-Cuts (in performance and fit). Are the wheels true? Do you need to change the front width? Can you use the flanged bearings?
Thanks in advance.
-Steve
bsmooth is offline   Reply With Quote
Old 12-13-2007, 09:12 AM   #1199
Thanks in advance.
-Steve
The offsets are different on a Jaco. I had to add one extra shim each side to the rear. Actually the Jaco makes the foam for the CRC tires. You can use flanged bearings. With Jaco's you have a little more of a choice of compounds.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 12-13-2007, 01:24 PM   #1200
Just a quick correction here...
Jaco does not make the foam for CRC tires. In fact, I'm very sure that Jaco does not make the foam for Jaco tires. CRC, GRP, Parma, BSR and Jaco all get foam that originates from the same factory in Japan.
CRC pioneered the big wheel craze that has now been "implemented" by every other manufacturer. Our Pro Cuts have won Regional, National and World Championships.
When comparing to other brands, CRC front wheels have a slightly larger OD. It also appears that our wheels are a bit more stiff than the rest. Another nice feature is the design of he rear wheel puts additional bracing around the mounting area. We like to think that this design allows our rear wheels take hit better than other wheels.
With our new, more efficient mounting and truing, a few months ago, CRC drastically lowered the price of the tires to distributors allowing them to sell to the dealers cheaper. We hope that dealers pass this savings on to the final consumer. As tires stock moves through the system, we are beginning to see prices on the Pro Cuts drop to the sub $12 range.
Best tires, great price. But of course I am biased!
Thanks,
Frank
Team CRC is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
