Old 11-27-2007, 04:54 PM   #1171
Ffejdat's Avatar
Thanks for the clear answer Mark, makes sense....
Ffejdat is offline   Reply With Quote
Old 11-27-2007, 05:39 PM   #1172
Maybell's Avatar
Originally Posted by microcrazy24 View Post
I watched the owner of crc on www.rctvlive.com the other day. He talked about new front end parts that should be out. Does anyone know what I am talking about and when they will be out?
the new front end parts have been available for a little wile from the CRC website....checkemout at teamcrc.com
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-27-2007, 07:59 PM   #1173
Who knew Frank liked to talk so much. It was a good.
Ginsu is offline   Reply With Quote
Old 11-27-2007, 08:29 PM   #1174
wallyedmonds's Avatar
Originally Posted by Ffejdat View Post
I have a dumb but serious technical question for Gen-x owners, has anyone tried running a Gen-X with an ASSOCIATED frontend, I know, it's like putting a ford motor in a chevy... but I am serious, just wondering if anyone has tried it and what they thought.....Thanks!
dude dont do it
but if you want to try,i think you'll use the crc front end and like it better.
wallyedmonds is offline   Reply With Quote
Old 11-27-2007, 08:32 PM   #1175
Originally Posted by chicky03 View Post
Here is my setup from the Indoor champs for 19T. Aaron and I ran the same thing. If you have any questions let me know.
thx
Old 11-28-2007, 08:21 AM   #1176
Johnny Wishbone's Avatar
Paul, when you say you glued the tires is that the side walls?
I see someone posted the side spring breakdown, but does anyone have the mid spring ratings?
Old 11-28-2007, 08:45 AM   #1177
chicky03's Avatar
Send a message via AIM to chicky03
Yea the side walls.
The center spring colors softest to hardest:
Black
Green
Silver
blue
gold
red
copper
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-28-2007, 12:59 PM   #1178
smyka's Avatar
Send a message via AIM to smyka
i figured it would be easier to do this once then do it a hundred times in pm's
here is my stock and 19 turn set up from cleveland
(and i am not cool like chickey so i have to type mine)
front end
.45 front springs
3 degrees caster i measure it so shim to get it
1 degree camber right side 1.2 left
servo angled
short arm
h brace but not caster brace
batteries forward
red center shock
losi 27.5 oil
front of ball shimmed up .60
rear roar max width
tubes had losi 15000 diff fluid in them
tires jaco yellow rears cut to 1.69 jaco meganta fronts cut to 1.61
full rears 1/4 fronts dope
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 11-28-2007, 08:33 PM   #1179
Smyka,
Thanks for the set up. Few more questions.
-How much rear pod droop?
-what side springs?
-how much pre load?
-why do you end up going with the short arm?
-what was your role out it in stock? Brushes/Springs?
-Ib's or EP's? Charge rate?
I think that is it
Thanks,
Jeremy
Jeremy Otis is offline   Reply With Quote
Old 11-29-2007, 10:41 AM   #1180
Old 11-29-2007, 11:48 AM   #1181
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Smyka,
I'll have to try that set up.. I was only able to qualify 2nd
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 11-29-2007, 12:33 PM   #1182
smyka's Avatar
o crap wayne knows my set up now hahahaha
as for everyone else i used white side springs and i bring them all the way to the top of the cross brace and go three full turns down then tweak
roll out it all depends on track and motor i had some old e brushes that work very good for some reason in the motors with two green springs but i did go fast with a green and blue and two green brushes
roll out wayne will laugh but i was at a 1.85 for the main i know he was well into the 2.0 rainge
pod droop i had about 1mm in it and 3.5 ride height
Old 11-29-2007, 12:40 PM   #1183
sg1
sg1's Avatar
Old 11-29-2007, 01:33 PM   #1184
Default Roll Out
Originally Posted by sg1 View Post
2.035
I tried 2.05 in one practice round and then settled with 1.83
brianrice is offline   Reply With Quote
Old 12-01-2007, 05:47 AM   #1185
Send a message via AIM to Carpetracer92
hey guys i want to make my servo flat with out using shoo glue. so does crc sell anytihng that makes it flat cause the ones it comes with makes it look like a angle.
Check out Long Island Low N Slow
Garage= Slammed g37,Full Exhaust
Carpetracer92 is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
