Old 11-09-2007, 01:15 PM   #1111
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Makes car smoother, less camber gain. I run 3000-5000 wt on my kigpins. Just a few drops. If the stearing block feels stuck to the pivot ball, too much.
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 11-09-2007, 05:44 PM   #1112
pokie's Avatar
Can someone please tell me the tools and respective sizes needed for assembly and maintenance of the Gen-X?
Thank You Very Much
pokie is offline   Reply With Quote
Old 11-09-2007, 07:21 PM   #1113
Maybell's Avatar
Thank You Very Much
Hex wrench sizes: .050, 1/16, 3/32 and 2mm for camber
nut drivers: 3/16, 11/32
I might have missed something, but I think that takes care of most of it...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-12-2007, 08:06 PM   #1114
C_O_jones's Avatar
Originally Posted by brianrice View Post
You can flip the servo so that the case extends to the opposite side of the chassis and there are holes pre-drilled for the KO servo.
See page 15 here:
http://www.teamcrc.com/crc/downloads...manual_web.pdf
Thanks Brian, guess ya just have to be smarter than the box it came in!
Oh, yah, instruction book, should read that some time, haha!
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 11-13-2007, 12:42 PM   #1115
Default Updated Setup
Just posting an updated setup for Brushless 17.5 (Stock). I picked up almost 3 tenths a lap over the previous week and the car is definitely closer to what I've been wanting in driving and handling. And yes, this setup TQ'd and won.
Front:
CRC Magenta Fronts with 3/4 width soak
Springs: .45mm
CRC White cap (Heavy) lube on kingpins
Caster: 10 block, 3 shims back, 0 forward (full caster in)
Ride height: 3.5mm
Toe In/Out: 0
Mid:
Spring: Gold (Associated)
Oil: 30Wt
Battery in Rear position
Rear pod level with chassis in race trim
Rear:
CRC Pink Rears with full width soak
Side springs: Red, 2 turns preload
Damper Tubes: CRC White cap (heavy)
Ride height: 4mm
Pod droop: 2mm
3.11 rollout (43/78 with 1.80" tires)
Parma Speed 8 Body
Dual rate was set so that the car did circles half the width of a 6 foot lane. I did not use full lock in the turns, and most turns are 180's.
Traction was about low/medium, more on the medium side I would say. A good groove was visible but nothing like a major event or anything. It was just a regular weekly race.
CShearburn is offline   Reply With Quote
Old 11-13-2007, 01:10 PM   #1116
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
since you have to mount the front brace on the top of the lower arm, doesnt it change your roll center?
R.Dalnogare is offline   Reply With Quote
Old 11-13-2007, 04:28 PM   #1117
wallyedmonds's Avatar
yes
but it helps with edging in mid corner.
and the new long ball will help more on high bit tracks.
wallyedmonds is offline   Reply With Quote
Old 11-13-2007, 06:27 PM   #1118
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Default red bumpers
Hey guys. Red bumpers just showed up at the Slapmaster Shop. Now you can dress your CRC & Corally's in style..... and then bash them senseless The red bumpers are #105R, the traditional black ones are just #105. The bumper was recut some to reduce sanding/cutting around the front suspension. The are cut and sanded so that a Speed 8 & 12 fit nicely.
Brian
www.slapmastertools.com
Slapmaster6000 is offline   Reply With Quote
Old 11-13-2007, 06:28 PM   #1119
Brian
sweet got to get one.
Old 11-13-2007, 07:40 PM   #1120
Send a message via AIM to Deznuts05
Originally Posted by wallyedmonds View Post
yes
so pretty much if you get the brace you have to get the longer ball studs?
Deznuts05 is offline   Reply With Quote
Old 11-13-2007, 07:56 PM   #1121
The new brace has the mounting holes for both the long and short pillow balls(old location and new locatiion)
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-13-2007, 08:02 PM   #1122
thats right
if your at a race and you feel your car needs it you can change the front end.
its fast and easy
from no brace to brace to brace with long upper ball,i think its great.
Old 11-14-2007, 09:13 AM   #1123
thanks!
any word on when the BL rear pod is going to be released?
Old 11-14-2007, 01:55 PM   #1124
thanks!
Generation X notes...
The current batch of Gen-X cars has the new left side bulkhead in the kit. In stock trim, we think that pod setup is the best rear pod available for brushless. In addition to the left bulkhead, the current batch of kits includes the molded ride height spacers for the Pro Strut front end.
News from the CRC camp...
Good news... We will release the new Open-X pod to fit the Gen-X at the US Indoor Champs in Cleveland. The conversion is a snap, a couple screws and you are ready to roll.
The new Open-X pod raises the bar one more notch when it comes to strength, lightweight and ease of use. The design results in the rear pod being more rigid and wide open on the left side, well beyond any other pod on the market.
There will be a limited supply, so see the store at the Champs early.
Team CRC is offline   Reply With Quote
Old 11-14-2007, 04:09 PM   #1125
and i cant go AHHHHHHHHHHHH
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
