Old 11-04-2007, 05:10 PM   #1096
protc3's Avatar
Just remember to tuck it in before you pull your zipper up and you will be fine All is good here dude. Hows work treating ya. Give a buzz sometime.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-05-2007, 07:16 PM   #1097
Wondering if anyone would have some set up tips for the gen x. I just ordered one, i am new to 1/12 after watching them race yesterday I had to have one. Also any electonics you think would work well in the stock class would be a great help. Thanks
jwaltz is offline   Reply With Quote
Old 11-05-2007, 11:29 PM   #1098
The stock set-up for the gen x is great. For stock racing you can't go wrong with the CO27 motor from Trinity. I used to run a Novak GTX before I got a 4 cell GTB and it is a small and very smooth ESC that was great in my gen x.
Kane-o is offline   Reply With Quote
Old 11-06-2007, 06:33 PM   #1099
wallyedmonds's Avatar
gtx is ok for brushed but the gtb is too big
the lrp is better for BL.
or wait for tekin
wallyedmonds is offline   Reply With Quote
Old 11-06-2007, 06:37 PM   #1100
Maybell's Avatar
If you start reading back a few pages on this thread, you will find all the info you could possibly want....Google "mark payne blog" for great building tips...
the CRC site has many great setups....so if you are running stock for example, try the Firshing setup...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-06-2007, 09:08 PM   #1101
Originally Posted by Quante View Post
I'll get back to you how this setup works for me.
So whats the word?
CShearburn is offline   Reply With Quote
Old 11-07-2007, 12:14 AM   #1102
Been real busy the last few days, but I've tried your setup.
Sorry to say, but it didnt work for me, I had lots of steering power going into the corner, but lost it half way through. With the batteries on the forward position this wasbetter but still not ok.
I did manage to make the car work pretty well though and the big change was: tires.... I went to Jaco double pink rears and purple fronts...
I'm gonna write up my setup as I remember it:
Front:
Springs: 0.45
Caster: 5 degree block, 2 shims front
Ride height: 3.5mm
Toe In/Out: 0
Corally Red Syrup on the kingpin
Mid:
Spring: Silver
Oil: 30Wt
Batteries forward
Rear pod aligned flat
Rear:
Side springs: Red, 1 turn preload
Damper Tubes: CRC White cap
Ride height: 4mm
Pod droop: 2mm
Car was easy to drive, very precise cornering and not much difference between the start and end of the 8 minutes.
Mid to low grip carpet, technical track, 10.5t Orion.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 11-07-2007, 07:25 AM   #1103
Oh wow, I thought you were running stock.... lol. Yea I would imagine my setup will need some work with a 10.5 in the car. Your front spring and caster block setup is interesting, I may try that myself. I'm racing tonight so hopefully I'll have time to try some of the stuff I've been wanting to.
Old 11-07-2007, 10:24 PM   #1104
C_O_jones's Avatar
Any sugestions to mount a KO PDS947 servo on the GenX without using the ugly black plastic mounts, the KO is to wide for the mounting holes.
Thanks, Fred
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 11-08-2007, 06:45 PM   #1105
Thanks, Fred
sell it and get a fut or JR
Old 11-08-2007, 08:18 PM   #1106
C_O_jones's Avatar
Ha ha!
but Iv'e had it forever, it's still faster and just won't break, no matter how hard I try.
Got a JR DS3400G, just doesn't feel as good. Just have to drill the double hole like my Xray.
But thanks for the moral support Walley
Bacon is Meat Candy
Old 11-09-2007, 06:02 AM   #1107
Mr. Bubby's Avatar
Axe the mounts, don't even use the mounting blocks. Just "Shoo Goo" the entire servo to the chassis. Obviously when you do this you'll have to switch the servo save so the links are on top, and you'll have to switch the right/left on your radio. But that's how the fast guys do it. Just remember when you do this, it will be a "pain in the arse" to get it off the chassis. But hopefully you won't have to. Hope this helps
Mr. Bubby is offline   Reply With Quote
Old 11-09-2007, 06:24 AM   #1108
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Mounting the servo like that will make it harder to drive. It's a good idea if you have no options, but not as easy to drive. The acerman is totally changed and bump stear my be introduced. I ran my t-bar car like that to get it to turn, I tried it on my gen-x and couldn't drive it.
just my .02
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
Old 11-09-2007, 09:33 AM   #1109
Thanks, Fred
You can flip the servo so that the case extends to the opposite side of the chassis and there are holes pre-drilled for the KO servo.
See page 15 here:
http://www.teamcrc.com/crc/downloads...manual_web.pdf
brianrice is offline   Reply With Quote
Old 11-09-2007, 12:23 PM   #1110
Has anyone tried the longer pillow balls, and how does it effect the car?
Also when you put lube on the kingpins how much do you put on them?
IMTK422 is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
