Old 11-02-2007, 09:49 AM   #1081
Johnny Wishbone's Avatar
Default Gen X Loaded droop
Can someone give me a better explanation of measuring and setting the loaded droop setting on this car. I believe unloaded droop is measured without the motor, and rear axle in place (correct?). But when it comes to the loaded, man I'm lost. What methods do some of you use? Do you have to use droop blocks? Is there another way top do it? Anyone care to share the knowledge?
Old 11-02-2007, 10:33 AM   #1082
Jack Smash's Avatar
Trader Rating: 29 (100%+)
How are you guys setting dropp in your front ends? Is that leaving the spring a little loose on the kingpin by not tightenting it up until it touches? and isn't .5" (1/2") a little much?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 11-02-2007, 10:36 AM   #1083
mtveten's Avatar
Trader Rating: 27 (100%+)
I think what you are looking for is the pod sag. For droop I first measure my up travel by placing my car on blocks and measuring the my rear pod at the rear of the bottom plate. It sounds like the value you are looking for is achieved by measuring the ride height at the middle of the chassis and comparing it to the front & rear ride heights. For example if your ride height is set to 3.5mm fr/re but your car is 3.25mm in the middle you would have .25mm sag, that I have heard some refer to as loaded droop.
Mark
mtveten is offline   Reply With Quote
Old 11-02-2007, 10:40 AM   #1084
Front droop is .5 mm is what he talking about.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-02-2007, 10:43 AM   #1085
mtveten's Avatar
.5mm should be in the ballpark, I tend to prefer a bit less up travel and usually run around .25mm.
Mark
Old 11-02-2007, 10:47 AM   #1086
I'm running the .45 springs right now and have a little preload on them. When I was running the .50 I had about .25mm up travel also.
Steve Walter
Old 11-02-2007, 02:38 PM   #1087
Default easy way to set side springs without tweakboard
in response to the fellow who asked about setting his side springs.....
if you don't have a tweakboard, then it's still not hard to get pretty close with the side springs. I suggest you:
*remove all wheels and tires and pull out the rear axle
*sit the fully assembled car (less wheels) on a flat surface so chassis plate and lower pod plate are both laying flat on the surface
*back off on both side spring adjusters until you can see clearance between the bottom of both springs and the top surface of the pod's graphite lower plate
*slowly and gently turn in on one side spring's adjuster while watching the bottom of that spring and keep turning the adjuster in until the bottom of the spring JUST BARELY rests on the gaphite of the pod plate. Use caution to not compress the spring. It should just lightly touch. That setting will be 0 preload.
*repeat the same procedure on other side spring to achieve 0 preload on that one too (important that the car remains on the flat surface while doing this). this will achieve 0 preload on both springs and the chassis will tweak flat.
*as baseline, turn each side spring adjuster in equally 1/4 turn (easy to judge by looking at the allen wrench's handle or even the flats on a plain allen key)
this will be a very close to perfect starting setup (assuming you've done a good job of laying out your electronics so they are reasonably even and balanced). I've done this on many guy's cars as a basic starting point and then after fitting the axle and wheels, and putting their cars on my very sensitive tweakboard........the settings are very near spot on.
good luck and happy motoring
vafactor is offline   Reply With Quote
Old 11-02-2007, 03:10 PM   #1088
http://www.markpayneblog.blogspot.com/
This site has some amazing tips on how to set-up your car and get rid of any tweak that may be present.....check it out and it will help you with setting up those side springs right.
Kane-o is offline   Reply With Quote
Old 11-02-2007, 03:16 PM   #1089
What does putting different types of oils on the kingpins do, and how much do you put on?
IMTK422 is offline   Reply With Quote
Old 11-03-2007, 11:30 AM   #1090
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Default gen x set up
Hey guys,
I used to be a firm believer of the t-bar cars. I ran the gen-x for 2 weeks then at the Holloween Classic. I just want to share something I found out, I hope this hasn't been posted b4, I Notice I had to basically mount the entire font end b4 I mounted the rear. I did it rear first and the car was inconsistant. The front may have put a slight twist in the chassis that bound the links.
My next thing was to make up a tweek station that used 2 small gram scales. I would take the tubes off and check the tweek using the scales. 1 thing I noticed, I could back the springs off, and as soon as a spring touched you could see it on the scale. I would then be able to set both springs so they just touch the chassis, then make equal adjustments from there.
The car was money every time! I ran back to back compairisons between the gen-x and t-force and ran 8 seconds quicker with the gen-x.
Just my 2 cents..
Wayne
sg1 is offline   Reply With Quote
Old 11-03-2007, 06:50 PM   #1091
wallyedmonds's Avatar
the thicker the oil the quicker the reaction.
i use 50000 but some use nothing
its all in what you want.
wallyedmonds is offline   Reply With Quote
Old 11-03-2007, 06:54 PM   #1092
Originally Posted by sg1 View Post
Hey guys,
Just my 2 cents..
Wayne
setup and setting up is key to success
Old 11-04-2007, 11:47 AM   #1093
sg1
sg1's Avatar
So true wally. I used 3000 wt. on my kingpins. I like the more responsiveness feel. I also used 50mm springs with maybe .005" play.
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
Old 11-04-2007, 01:39 PM   #1094
protc3's Avatar
What do you know wayne!! How ya been bro?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-04-2007, 05:05 PM   #1095
sg1
sg1's Avatar
Hey Jay,
I know enough to get me in trouble!! lol.. How have you been?
Wayne
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
